Trying to setup a Icarus server and everything setup, but I’m trying to set it to work with myexternalIP:Port, but all it shows is 0.0.0.0:port, if I go into the instance via AMD and hover over the “connect to server” link, it shows 127.0.0.1… How can I change the IP so that others can also join?
0.0.0.0 just means it’s listening on every IP of the machine. So nothing to change there. You have to give your Friends your public IP and setup port forwarding.
