Not sure how to use AMP and UMOD, I started a RUST server and enabled UMOD but not sure where to put these umod plugins and enable then via AMP…
Any help would be appreciated!
the same issue, don’t see the oxide dir anywhere
Should be under Configuration and “Rust”
Then in the file manager the oxide folder will show up.
