Having panel login issues and could use a hand
OS Name/Version: Ubuntu 20.04
Product Name/Version: AMP 2.4.8
After installing AMP, I have been having issues staying logged in. If I refresh the page, I have to login again and sometimes it just hangs or shows me a box saying the browser cache needs to be cleared due to an update. Also, sometimes when I log in it goes straight to the performance monitor and doesn’t have an instances tab.
It’s getting to the point where I can’t even see the output of the console. It just says “You do not have permission to use this method (GSMyAdmin.WebServer.Start) at this time. This method requires the Session.Exists permission.”
  • Login
  • Refresh page
  • Login again, or at least try to (usually hangs at this point)
  • Run ampinstmgr upgradeall
  • Reboot server
Try turning off “Session IP stickiness” in the configuration.
Thanks Mike, seems to be working like a charm now. I guess it’s because I’m on my work network and my IP is all over the place.
