Greelan/AMPTemplates:dev is not working
Operating System Windows Server 2022 Standard Evaluation
Product AMP Release “Callisto”
v2.5.0.12, built 31/05/2024 14:46
Greelan/AMPTemplates:dev is not working in did all what i have to do but i dont see greelan instances i restartet amp i updated the instances nothing is working it looks like ist stuck
  • From your AMP homepage (not in an Instance), goto Configuration > Instance Deployment
  • Under the Configuration Respositories section, press add.
  • Type Greelan/AMPTemplates:dev and hit okay.
  • Press Fetch Latest, let AMP work (stuck in fetch mode)
i tryed it like here:
and i think its stuck: se here
i can do 1 time is stuck i can do it more times also stuck
need help thx
Same problem, if you find a fix please post it.
Same problem. Waiting for someone to provide a fix.
