Environment Variables
On Linux, GetAMP supports unattended installations to allow AMP to be automatically provisioned and started without requiring any input.
This is achieved by specifying a number of environment variables that the GetAMP script will pick up when executed.
When using HTTPS, a domain name needs to either be specified via EXT_HOSTNAME or it can be discovered automatically if reverse lookups are enabled for the external IP address.
| Flag | Description |
| USE_ANSWERS | Set to y to specify that you’d like to perform an unattended installation |
| ANSWER_AMPUSER | The username to be used for the ADS instance |
| ANSWER_AMPPASS | The password to be used for the above user |
| ANSWER_SYSPASSWORD | The password to be used for the amp system user |
| ANSWER_INSTALLJAVA | Set to y to specify that you’d like an appropriate Java version to be installed for running Minecraft |
| ANSWER_INSTALLSRCDSLIBS | Set to y to specify that you’d like 32-bit C++ libraries and other dependencies of Source Dedicated Servers (and other applications that rely on SteamCMD) to be installed |
| ANSWER_INSTALLDOCKER | Set to y to specify that you’d like Docker to be installed and configured, and for AMP to create instances inside containers by default |
| ANSWER_HTTPS | Set to y to specify that you’d like NGINX to be installed and configured |
| EXT_HOSTNAME | If reverse hostname lookup isn’t possible, what hostname to use for HTTPS |
| ANSWER_EMAIL | The email address to be used for LetsEncrypt certificate warnings (Optional) |
| SKIP_INSTALL | Set to y to install the AMP Instance Manager and dependencies, but do not create the ADS instance or set up a reverse proxy. Useful for Docker scripts |
Arguments
The GetAMP script accepts a number of arguments to perform individual tasks without performing a full installation, this takes the syntax of:
bash <(wget -qO- getamp.sh) ARGUMENT
| Argument | Description |
| addRepo | Adds the CubeCoders repository to the system |
| configureDarkMagicNew | Installs CPx2 on an existing ARM system |
| installAMP | Installs ampinstmgr, requires that the repository has already been added |
| installDocker | Installs Docker, enables the Docker service, and adds the amp user to the docker group |
| installJava | Installs Adopt OpenJDK 8 and 11 onto the system |
| installSrcdsDeps | Installs 32-bit dependencies and libraries for games based on the Source engine or that use SteamCMD |
| postSetupHTTPS | Installs and configures nginx and certbot for use with AMP |
| showSystemInfo | Displays information about the system gathered by GetAMP |
| update | Updates ampinstmgr to the latest version, and upgrades all AMP instances to the latest version |
| updateSystem | Applies any pending system updates using the systems package manager |
