OS Name/Version: Windows Server 2022
Product Name/Version: v2.4.0.8
Problem Description: I have been attempting create a Mount and Blade II: Bannerlord game server with AMP. Hypothetically, the server should work fine, and it does when launched manually, however when attempting to start the server with AMP it doesn’t work.
Starting new log file...
[08:24:13.185] Mount and Blade II Bannerlord Console Started...
[08:24:13.186] 16 Oct 2022 Sunday 08:24 Pacific Daylight Time
[08:24:13.186] Build Version: 2778
[08:24:13.212]
Unhandled Exception Code 0xC0000005 at adress 0x7FFB94F22D85
#Rgl.pdb@{BD72632A85F0498AB68A7E2CB17CAAEA} (1): 0:1846661
#Rgl.pdb@{BD72632A85F0498AB68A7E2CB17CAAEA} (1): 0:1399664
#Rgl.pdb@{BD72632A85F0498AB68A7E2CB17CAAEA} (1): 0:4592451
#Rgl.pdb@{BD72632A85F0498AB68A7E2CB17CAAEA} (1): 0:3553797
#Rgl.pdb@{BD72632A85F0498AB68A7E2CB17CAAEA} (1): 0:3553019
#Rgl.pdb@{BD72632A85F0498AB68A7E2CB17CAAEA} (1): 0:3557447
#ucrtbase.pdb@{D7E2A94EE919EC0411403F3658DBFB15} (1): 0:158540
#kernel32.pdb@{245B0C4ED38BC8A7EA86195A41055355} (1): 0:85712
#ntdll.pdb@{BDC961DA4CD474CA6128651F7A54B85F} (1): 0:516619
No managed frames available.
[08:24:13.213]
[08:24:13.213] Working Memory: 21 MB
[08:24:13.213] Commit Memory: 527 MB
[08:24:13.213] Page Allocator Memory:
[08:24:13.213] DumpTimeStamp: /2022-10-16_15.24.13
[08:24:13.213] AutoReport: Enabled
@ECHO OFF REM Generated by AMP cd /d "C:\AMPDatastore\Instances\MountBladeIIBannerlord01\bannerlord-server\1863440" "C:\AMPDatastore\Instances\MountBladeIIBannerlord01\bannerlord-server\1863440\bin\Win64_Shipping_Server\DedicatedCustomServer.Starter.exe" /dedicatedcustomserverauthtoken /dedicatedcustomserverconfigfile ds_config_big_sample_team_deathmatch.txt /port 7210 _MODULES_*Native*Multiplayer*_MODULES_
This is the .bat generated from AMP, those commandline args work perfectly when launched manually with a .bat located in the same folder as the .exe but refuses to work with AMP.
Any help would be appreciated.
