Hello,
Windows server 2019 version 1809
Ads updated of 2.5.0.8 to 2.5.0.10
Service not started
Uninstall, reboot, download from the official website for the latest amp version (2.5.0.10)
Full installation, reboot, Full installation, reboot
start services manually but also stops
Updated server
creating a new “AMP” user session
ditto do you have any solutions ?
cordially
I’ve had the same issue. Tried 3 different versions of Windows.
Thank you, no same where can you download version 2.5.0.8 to see if it works again thank you
what errors are you getting right now?
Where can i get an older version. Steamcmd is not started on new instance generation. Fresh Install. Windows 10 Pro and AMP. Clean new Installation.
Hello,
launching AMP Instance Manager
Amp and open the web interface ? No
Ads uninstalled service
Ads install
Boot OK
Created instal (v-rinsing) OK
Satrting instance No Ok
Log “21:30:06
Waiting for AMP instance to start…
21:30:12
Instance status is offline but process has not exited…
Slow method invocation: StartInstance took 5374ms to complete.
Slow response: ADSModule.StartInstance took 5375ms to complete.”
Kind regards
22:52 : - started instance OK
manage instance OK
Updated game no OK
system
Closed
17 June 2024 19:31
7
