FTB Evolution Stuck at v1.3.0
OS Name/Version: Ubuntu 20.04.6
Product Name/Version: AMP 2.6.0.12
Problem Description: Feed The Beast (New Source) only shows FTB Evolution 1.3.0 and no other versions. Current Release version from FTB is 1.11.1
  • Step 1 - Set Server Type to “Feed The Beast (New Source)”
  • Step 2 - FTB Modpack drop down, scroll down - only FTB Evolution 1.3.0 is in the list, no other versions of FTB Evolution.
-Stopped instance
-Manually removed ModpacksCache.json using the file manager
-Restarted the instance - issue remains
Additional Notes: Searched the forum - seems I am not the only one, but no remedies cited to make AMP actually load the full current version lists from FTB.
FTB changed their download API, so you’ll want to grab the server installer from their site, run it on your PC, then upload those files to AMP
Do you know if there are any plans for updating AMP to deal with FTB’s new API?
The new API is undocumented, so it may take some time to sort out
