Field
Value
Operating System
Product
AMP ‘Phobos’ v2.6.0.6 (Mainline)
Virtualization
Docker
Application
Minecraft
Module
MinecraftModule
Running in Container
Yes
Current State
Stopped
Can’t get server to run so client can join from official FTB app
start new minecraft instance
select FTB new source, FTB Evolution 1.3.0
client can’t connect (server version 1.21.3)
You need to select the modloader and version after installing the modpack
Forge Frequently Asked Questions
How do I run Forge using: start.sh/start.bat?
No need! AMP handles all that for you. Just select the version of Forge you’ll need, hit update, and start your server.
Where do I put custom start up arguments?
You can find this options under:
Configuration → Minecraft → Java and Memory → Additional java options
I installed a modpack using AMP’s FTB downloader, why did it start in Vanilla? or The update manager reported a successful update, but ./Minecraft/minecr…
so first i select Configuration → Server Settings → Server Type → Feed The Beast (New source) and select FTB Modpack below then press Download/Update. and after this is finished I change it to Configuration → Server Settings → Server Type → Neoforge and select correct version for it and run the server?
Yeah, you Download/Update with the modpack selected, then select the right version and modloader once it’s done
