Forge not working
OS Name/Version: Linux/Ubuntu
Product Name/Version:
Problem Description: Forge is not working
18:04:51
		/ mixin TRANSFORMATIONSERVICE
	FML Language Providers:
		minecraft@1.0
		lowcodefml@52
		javafml@52.1.2
	Mod List:
		forge-1.21.1-52.1.2-server.jar                    |Minecraft                     |minecraft                     |1.21.1              |NONE      |Manifest: NOSIGNATURE
		forge-1.21.1-52.1.2-universal.jar                 |Forge                         |forge                         |52.1.2              |NONE
[22:04:51] [main/ERROR] [minecraft/Main]: Failed to start the minecraft server net.minecraftforge.fml.LoadingFailedException: Loading errors encountered: [
	Mod ?etectonic?r requires ?6forge?r ?o?r
?7Currently, ?6forge?r?7 is ?o52.1.2,
	Mod ?etectonic?r requires ?6minecraft?r ?o?r
?7Currently, ?6minecraft?r?7 is ?o1.21.1
	at LAYER PLUGIN/net.minecraftforge.fmlcore@1.21.1-52.1.2/net.minecraftforge.fml.ModLoader.gatherAndInitializeMods(ModLoader.java:162) ~[fmlcore-1.21.1-52.1.2.jar:1.0]
	at TRANSFORMER/net.minecraftforge.forge@52.1.2/net.minecraftforge.server.loading.ServerModLoader.load(ServerModLoader.java:30) ~[forge-1.21.1-52.1.2-universal.jar:?]
	at TRANSFORMER/minecraft@1.21.1/net.minecraft.server.Main.main(Main.java:129) ~[forge-1.21.1-52.1.2-server.jar:?]
	at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?]
	at java.base/java.lang.reflect.Method.invoke(Method.java:580) ~[?:?]
	at SECURE-BOOTSTRAP/net.minecraftforge.fmlloader@1.21.1-52.1.2/net.minecraftforge.fml.loading.targets.CommonLaunchHandler.runTarget(CommonLaunchHandler.java:85) ~[fmlloader-1.21.1-52.1.2.jar!/:?]
	at SECURE-BOOTSTRAP/net.minecraftforge.fmlloader@1.21.1-52.1.2/net.minecraftforge.fml.loading.targets.CommonLaunchHandler.lambda$makeService$0(CommonLaunchHandler.java:69) ~[fmlloader-1.21.1-52.1.2.jar!/:?]
	at SECURE-BOOTSTRAP/cpw.mods.modlauncher@10.2.4/cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:77) [modlauncher-10.2.4.jar!/:?]
	at SECURE-BOOTSTRAP/cpw.mods.modlauncher@10.2.4/cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:97) [modlauncher-10.2.4.jar!/:?]
	at SECURE-BOOTSTRAP/cpw.mods.modlauncher@10.2.4/cpw.mods.modlauncher.Launcher.run(Launcher.java:116) [modlauncher-10.2.4.jar!/:?]
	at SECURE-BOOTSTRAP/cpw.mods.modlauncher@10.2.4/cpw.mods.modlauncher.Launcher.main(Launcher.java:75) [modlauncher-10.2.4.jar!/:?]
	at SECURE-BOOTSTRAP/cpw.mods.modlauncher@10.2.4/cpw.mods.modlauncher.BootstrapEntry.main(BootstrapEntry.java:17) [modlauncher-10.2.4.jar!/:?]
	at net.minecraftforge.bootstrap@2.1.7/net.minecraftforge.bootstrap.Bootstrap.moduleMain(Bootstrap.java:188) [bootstrap-2.1.8.jar!/:?]
	at net.minecraftforge.bootstrap.Bootstrap.bootstrapMain(Bootstrap.java:133) [bootstrap-2.1.8.jar:2.1.8]
	at net.minecraftforge.bootstrap.Bootstrap.start(Bootstrap.java:53) [bootstrap-2.1.8.jar:2.1.8]
	at net.minecraftforge.bootstrap.ForgeBootstrap.main(ForgeBootstrap.java:19) [bootstrap-2.1.8.jar:2.1.8]
	at net.minecraftforge.bootstrap.shim.Main.main(Main.java:101) [forge-1.21.1-52.1.2-shim.jar:2.1.8]
Transformer Audit:
    REASON: classloading
  • Install Forge onto the instance
  • Download Pixlemon from the server using from server pack download button
  • Drag it into the file manager in the instance
  • Unzip that folder
  • Start the server; it works
  • After 2 minutes, an error
I wanted to set up Pixlemon for me and my friends. I used a tutorial, but instead of following the directions for downloading the server pack, I used the “download server pack” button, dragged the zip file into the file manager, then unzipped that file. Now it works, but on Minecraft, it says “getsockopt,” then after like 2 minutes, it says error. I will send the console log, and I simplified it so you can see the main error
