i have the text
copied over from the ticket system because I couldn’t create a ticket
OS Name/Version: ubuntu 20.04 x86_64 - amp version 2.4.6 - 20230809.1
Product Name/Version:
the server does not state and the server.cfg is always reset so that you cannot change it
- Step 1 changed the server config
- Step 2 looked in the fiveM forum
- Step 3 the instance updated and then server
step 4 the server does not state and the server.cfg is always reset so that you cannot change it
Detailed Description
is an initial installation
but I have already entered a key and a steam api key
what the console outputs:
Console Listener setup OK
Started map fivem-map-hipster
Started resource fivem-map-hipster
server thread hitch warning: timer interval of 181 milliseconds
fff
cccc ff xx xx rr rr eee
cc ffff xx rrr r ee e
cc ff xx … rr eeeee
ccccc ff xx xx … rr eeeee
Authenticated with cfx.re Nucleus: https://********************.users.cfx.re/
– [server notice: hostname_rework]
You don’t have sv_projectName/sv_projectDesc set.
These variables augment sv_hostname and fix your server name being cut off in the server list.
Use sets sv_projectName ..
and sets sv_projectDesc ..
to set them.
