OS Name/Version: Ubuntu 20.04.6 LTS
Product Name/Version: AMP Release “Decadeus” v2.4.3
Problem Description: After creating the instance, the server can’t be installed via the “Update” button. The download for the files start, but the unpacking stalls with following error:
This task could not be completed: Updating FiveM Server - Extracting... - State: 3.
Unpack operation failed with exit code 2
- Create new FiveM-Instance (doesn’t matter if a docker container is used or not)
- Start instance and update/install gameserver files via button “Update”
- Observer error
- Deleted and redeployed instance
- Switched off instancedeployment in a docker container
Thank for your help in advance!
EDIT:
To me appears that the file format of the archive is wrong, because a ‘.zip’ is handled like a ‘.tar.gz’:
I downloaded the archive and converted it to a ‘.tar.gz’ but sadly I can not alter the unzip command used by AMP.
