i have installed git but when i start the FiveM server up is says git is not installed or not in the PATH, i have installed git correctly and chose the console option.
i also pasted the most recent .dll in the folder but it stil doesn’t work
If you open a command prompt and just type git
does it show you the help for it? If so, reboot the system.
got git working, but now the server gives me this:
Server list query returned an error: System.Threading.Tasks.TaskCanceledException: The operation was canceled. ← System.TimeoutException: The operation was canceled. ← System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing.
its not a port forwarding issue as i set up port forwarding already and tested the ports needed
That’s an issue you should bring up with the FiveM community. That’s not something in AMPs control.
