Fistful of Frags Application Error A Fault is Preventing the Application From Starting
OS Name/Version: Elementary OS 8
Product Name/Version: AMP Phobos v2.6.0.6
Problem Description: Trying to setup a server for Fistful of Frags. It appears as though it gets installed but it won’t start. I get an application error - a fault is preventing the application from starting. Manage the instance to examine the logs. I’ve read through the logs and, while I can understand some aspects of it, I’m not sure exactly what to take away from it.
[21:13:24] [Program Info/1]       : Starting AMP version 2.6.0.6 (Phobos), built 20/11/2024 20:57
[21:13:24] [Program Info/1]       : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[21:13:25] [Program Warning/1]    : Current time zone is set to Eastern Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[21:13:25] [Program Info/1]       : OS: Linux / x86_64
[21:13:25] [Program Info/1]       : CPU: Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz (8C/16T)
[21:13:25] [Program Info/1]       : RAM: 7865MB
[21:13:25] [Program Info/1]       : AMP Instance ID: a1fe870b-d2ad-4b84-807c-5e307933a94c
[21:13:27] [Core Info/1]          : Loaded srcdsModule version 2.6.0.6 by CubeCoders Limited
[21:13:27] [Core Info/1]          : Metrics publishing is enabled at udp://localhost:12820.
[21:13:28] [Loader Info/1]        : Loaded FileManagerPlugin by CubeCoders Limited
[21:13:28] [Loader Info/1]        : Loaded EmailSenderPlugin by CubeCoders Limited
[21:13:29] [Loader Info/1]        : Loaded WebRequestPlugin by CubeCoders Limited
[21:13:31] [Loader Info/1]        : Loaded LocalFileBackupPlugin by CubeCoders Limited
[21:13:31] [Loader Info/1]        : Loaded CommonCorePlugin by CubeCoders Limited
[21:13:32] [Loader Info/1]        : Loaded AnalyticsPlugin by CubeCoders Limited
[21:13:32] [System Error/9]       : Missing plugin/assembly: MaxMind.Db (/home/amp/.ampdata/instances/FoF01/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[21:13:32] [Loader Info/1]        : srcdsModule requests dependency steamcmdplugin...
[21:13:32] [Loader Info/1]        : Loaded steamcmdplugin by CubeCoders Limited
[21:13:32] [Loader Info/1]        : srcdsModule requests dependency RCONPlugin...
[21:13:32] [Loader Info/1]        : Loaded RCONPlugin by CubeCoders Limited
[21:13:32] [Core Info/1]          : Licence Present: AMP Standard Edition - Lifetime Licence
[21:13:33] [Loader Notice/1]      : Using keypair with fingerprint h6Wc5MvwgYe0NifztO/9LRoXd4EFGld5SsfmPKim3PU=
[21:13:33] [Loader Info/1]        : SFTP Server started on 0.0.0.0:2225
[21:13:35] [Core Info/1]          : Webserver started on http://127.0.0.1:8082
[21:13:35] [System Info/9]        : Startup mode is UpdateAndStart.
[21:13:35] [System Info/12]       : Checking for AMP updates...
[21:13:35] [System Warning/9]     : 2024/12/06 16:13:35 socat[1837671] W ioctl(6, TIOCSCTTY, NULL): Operation not permitted
[21:13:35] [System Warning/9]     : 2024/12/06 16:13:35 socat[1837671] W tcsetpgrp(1837671): Inappropriate ioctl for device
[  0%] Checking for available updates...
[21:13:37] [System Info/9]        : AMP is up to date.
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1733269577
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "295230"
Waiting for user info...OK
app_update 295230 validate
 Update state (0x5) verifying install, progress: 0.17 (5696410 / 3325487751)
 Update state (0x5) verifying install, progress: 14.57 (484592900 / 3325487751)
 Update state (0x5) verifying install, progress: 14.68 (488057373 / 3325487751)
 Update state (0x5) verifying install, progress: 19.51 (648670452 / 3325487751)
 Update state (0x5) verifying install, progress: 38.98 (1296404016 / 3325487751)
 Update state (0x5) verifying install, progress: 54.64 (1816884556 / 3325487751)
 Update state (0x5) verifying install, progress: 66.21 (2201897808 / 3325487751)
 Update state (0x5) verifying install, progress: 76.29 (2536874122 / 3325487751)
 Update state (0x5) verifying install, progress: 83.59 (2779862764 / 3325487751)
 Update state (0x5) verifying install, progress: 96.35 (3203943387 / 3325487751)
 Update state (0x5) verifying install, progress: 98.93 (3289993720 / 3325487751)
 Update state (0x61) downloading, progress: 0.00 (0 / 8)
IPC function call IClientAppManager::GetUpdateInfo took too long: 72 msec
Success! App '295230' fully installed.
IPC function call IClientUGC::GetAppItemsStatus took too long: 152 msec
quit
[21:14:13] [System Info/9]        : SteamCMD Update successful
[21:14:18] [srcds Info/9]         : Source RCON disconnecting...
[21:14:18] [srcds Error/9]        : Source RCON failed to disconnect:
Object reference not set to an instance of an object.
[21:14:18] [RCON Error/9]         : NullReferenceException
[21:14:18] [RCON Error/9]         : [0] (NullReferenceException) : Object reference not set to an instance of an object.
[21:14:18] [RCON Error/9]         :    at RCONPlugin.SourceRconClient.Disconnect()
[21:14:18] [System Warning/9]     : Server failed to start 1/5 times...
[21:14:22] [srcds Info/18]        : Source RCON disconnecting...
[21:14:22] [srcds Error/18]       : Source RCON failed to disconnect:
[21:14:22] [RCON Error/18]        : NullReferenceException
[21:14:22] [RCON Error/18]        : [0] (NullReferenceException) : Object reference not set to an instance of an object.
[21:14:22] [RCON Error/18]        :    at RCONPlugin.SourceRconClient.Disconnect()
[21:14:22] [System Warning/18]    : Server failed to start 2/5 times...
[21:14:26] [srcds Info/9]         : Source RCON disconnecting...
[21:14:26] [srcds Error/9]        : Source RCON failed to disconnect:
[21:14:26] [RCON Error/9]         : NullReferenceException
[21:14:26] [RCON Error/9]         : [0] (NullReferenceException) : Object reference not set to an instance of an object.
[21:14:26] [RCON Error/9]         :    at RCONPlugin.SourceRconClient.Disconnect()
[21:14:26] [System Warning/9]     : Server failed to start 3/5 times...
[21:14:29] [srcds Info/9]         : Source RCON disconnecting...
[21:14:29] [srcds Error/9]        : Source RCON failed to disconnect:
[21:14:29] [RCON Error/9]         : NullReferenceException
[21:14:29] [RCON Error/9]         : [0] (NullReferenceException) : Object reference not set to an instance of an object.
[21:14:29] [RCON Error/9]         :    at RCONPlugin.SourceRconClient.Disconnect()
[21:14:29] [System Warning/9]     : Server failed to start 4/5 times...
[21:14:32] [srcds Info/15]        : Source RCON disconnecting...
[21:14:32] [srcds Error/15]       : Source RCON failed to disconnect:
[21:14:32] [RCON Error/15]        : NullReferenceException
[21:14:32] [RCON Error/15]        : [0] (NullReferenceException) : Object reference not set to an instance of an object.
[21:14:32] [RCON Error/15]        :    at RCONPlugin.SourceRconClient.Disconnect()
[21:14:32] [System Warning/15]    : Server failed to start 5/5 times...
[21:14:35] [srcds Info/15]        : Source RCON disconnecting...
[21:14:35] [srcds Error/15]       : Source RCON failed to disconnect:
[21:14:35] [RCON Error/15]        : NullReferenceException
[21:14:35] [RCON Error/15]        : [0] (NullReferenceException) : Object reference not set to an instance of an object.
[21:14:35] [RCON Error/15]        :    at RCONPlugin.SourceRconClient.Disconnect()
[21:14:35] [System Warning/15]    : Server failed to start 6/5 times...
[21:14:35] [System Warning/15]    : Server failed to start 5 times, not restarting.
  • Create Instance
  • Pick Fistful of Frags
  • Create Instance
Actions taken to resolve so far: I’ve searched both here and on google, but I’m not finding anything related specifically to FoF. I’ve stopped and started the instance to no avail. I have also deleted and recreated the instance.
The srcds module is currently broken.
A generic module version of FOF will be available very soon.
