First time startup factorio
Windows Server 2022
After the Instance is createt i press update and enter my steam login data after the login window he ask for my auth key after i enter the key ino the consol nothing happened.
create Instance
press update
(steam name blured)
[23:40:43] [Program Info] : Starting AMP version 2.4.6.8 (Decadeus), built 26/11/2023 20:19
[23:40:43] [Program Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[23:40:43] [Core Info] : Purging old audit logs (this may take a moment)…
[23:40:43] [Core Warning] : Current time zone is set to Mitteleuropäische Zeit - It is recommended you switch to UTC+0 to avoid time-zone related issues
[23:40:43] [Program Info] : OS: Windows / x86_64
[23:40:43] [Program Info] : CPU: 13th Gen Intel(R) Core™ i5-1340P (12C/16T)
[23:40:43] [Program Info] : RAM: 32316MB
[23:40:43] [Program Info] : AMP Instance ID: a611e66f-fd66-4c0d-90f7-64732255709a
[23:40:43] [Loader Info] : Loaded FactorioModule version 1.0.0.0 by CubeCoders Limited
[23:40:43] [Core Info] : Metrics publishing is enabled at udp://127.0.0.1:12820.
[23:40:43] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[23:40:43] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[23:40:43] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[23:40:43] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[23:40:43] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[23:40:43] [Core Info] : Licence Present: AMP Advanced Edition
[23:40:43] [Loader Info] : Loaded steamcmdplugin by CubeCoders Limited
[23:40:43] [FileManager Notice] : No SSH keypair available for embedded server, generating new keypair…
[23:40:43] [FileManager Notice] : Generated new keypair with fingerprint gF32hwY/aZ6afRRGLCGgMb355rWEv8yqNgd9LIBu668=
[23:40:43] [FileManager Notice] : Using keypair with fingerprint gF32hwY/aZ6afRRGLCGgMb355rWEv8yqNgd9LIBu668=
[23:40:43] [FileManager Info] : SFTP Server started on 0.0.0.0:2226
[23:40:43] [Webserver Info] : Websockets are enabled.
[23:40:43] [Webserver Info] : Webserver started on http://127.0.0.1:8083
[23:40:43] [Webserver Info] : RouterTimer@10Hz with 2 jobs started
[23:40:43] [Core Info] : Checking for AMP updates…
[23:40:43] [Core Info] : Startup mode is StartApplication, SkipThisTime.
[23:40:43] [Core Info] : AMP is up to date.
[23:40:49] [Core Activity] : Authentication attempt for user Locke from 127.0.0.1
[23:40:50] [Core Activity] : Authentication success
[23:41:05] [API:Locke Activity] : Updating the application.
[23:41:15] [API:Locke Activity] : Updating the application.
CPID: 6128
Redirecting stderr to ‘C:\AMPDatastore\Instances\Factorio01\factorio\logs\stderr.txt’
ILocalize::AddFile() failed to load file “public/steambootstrapper_english.txt”.
[ 0%] Checking for available update…
[----] Downloading update (0 of 68,874 KB)…
[ 0%] Downloading update (0 of 68,874 KB)…
[ 0%] Downloading update (2,143 of 68,874 KB)…
[ 3%] Downloading update (9,974 of 68,874 KB)…
[ 14%] Downloading update (17,014 of 68,874 KB)…
[ 24%] Downloading update (21,748 of 68,874 KB)…
[ 31%] Downloading update (26,596 of 68,874 KB)…
[ 38%] Downloading update (29,008 of 68,874 KB)…
[ 42%] Downloading update (31,398 of 68,874 KB)…
[ 45%] Downloading update (33,743 of 68,874 KB)…
[ 48%] Downloading update (36,153 of 68,874 KB)…
[ 52%] Downloading update (38,605 of 68,874 KB)…
[ 56%] Downloading update (40,901 of 68,874 KB)…
[ 59%] Downloading update (43,282 of 68,874 KB)…
[ 62%] Downloading update (45,659 of 68,874 KB)…
[ 66%] Downloading update (48,071 of 68,874 KB)…
[ 69%] Downloading update (50,407 of 68,874 KB)…
[ 73%] Downloading update (52,743 of 68,874 KB)…
[ 76%] Downloading update (55,199 of 68,874 KB)…
[ 80%] Downloading update (57,615 of 68,874 KB)…
[ 83%] Downloading update (59,965 of 68,874 KB)…
[ 87%] Downloading update (62,304 of 68,874 KB)…
[ 90%] Downloading update (64,879 of 68,874 KB)…
[ 94%] Downloading update (67,232 of 68,874 KB)…
[ 97%] Downloading update (68,874 of 68,874 KB)…
[100%] Download Complete.
[----] Applying update…
[----] Extracting package…
[----] Installing update…
[----] Cleaning up…
[----] Update complete, launching…
Logging directory: ‘C:\AMPDatastore\Instances\Factorio01\factorio/logs’
[ 0%] Downloading update…
[----] Downloading update (0 of 45,231 KB)…
[ 0%] Downloading update (2,940 of 45,231 KB)…
[ 6%] Downloading update (11,977 of 45,231 KB)…
[ 26%] Downloading update (27,708 of 45,231 KB)…
[ 61%] Downloading update (41,503 of 45,231 KB)…
[ 91%] Downloading update (45,231 of 45,231 KB)…
[100%] Download complete.
[----] Cleaning up…
[----] Update complete, launching Steamcmd…
CWorkThreadPool::~CWorkThreadPool: work processing queue not empty: 6 items discarded.
Steam Console Client (c) Valve Corporation - version 1700160359
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “427520”
Logging in user ‘…’ to Steam Public…
password:
Enter the current code from your Steam Guard Mobile Authenticator app
[23:42:40] [API:Locke Activity] : Sent to console: RKQFB
