I’ve just tried to setup my first sub user, I have started with what I think are the minimum permissions for them to manage a single game server. They are able to login to the panel but are unable to manage the instance, they get the error “Failed to login to remote instance - Token Rejected. Full login required - No other reason given.”
The deployment log displays:
Access denied: You do not have permission to use this method (GSMyAdmin.WebServer.GetActiveAMPSessions) at this time. This method requires the Core.UserManagement.ViewActiveSessions permission. (Origin: 1.158.93.117)
around the time the user tries and then subsequently:
Managed remote instance at
Authentication token for requested by ManageInstance on behalf of
personal data removed inside < >’s
I have enabled the permission mentioned in the first error to no effect.
I’m assuming I’ve missed a permission but I’m a bit lost as to which one it would be?
