| Easy Installation |
Single-command install script |
Mostly automated, some manual steps required |
Multiple dependencies, long and complex installation process |
| Secure 2FA Support |
Supports WebAuthn for fingerprints, FaceID, YubiKey and other U2F providers as well as TOTP |
TOTP only |
TOTP only |
| Cross-Platform |
Supports both Windows and Linux |
Linux Only, no Windows support |
| Supports multiple games as standard |
Over 30 supported titles as standard, plus community supplied configurations |
Only Minecraft as standard |
Supports multiple games as standard, plus community supplied configurations |
| Extensible plugin architecture |
AMPs internal feature set is plugin driven, plugins have full access to AMPs internals |
No plugin system, only frontend can be modified by hand-crafted changes |
No plugin system, changes to source must be manually maintained and kept up-to-date |
| SDK and sample code for new features |
SDK available for Visual Studio, plus sample source code for modules and sample configurations |
No SDK, limited front-end modifications only |
No SDK, modifications must be manually kept up-to-date |
| Fine-grain permissions system |
On a global or per-instance basis, all AMP features or individual settings can be locked out from users |
Limited selection of fixed roles with zero customization |
No roles, limited user-driven permissions system |
| Docker Support for games |
Optional, instances can run either inside or outside of containers. |
Optional |
Mandatory, games must run inside of containers even if unwanted |
| Automatic firewall configuration |
Automatic firewall configuration available for UFW, FirewallD, iptables and Windows Defender Firewall |
No automatic firewall configuration |
| Updates via system package manager |
Maintained DEB and RPM package repositories for installation and updates. |
Updates applied by re-running setup, no repository |
Multiple steps required to update, no repository |
| Automatic HTTPS setup |
Available on Linux via LetsEncrypt, configured automatically by setup script when given a domain. |
Manual configuration required |
| Mobile App |
Progressive web app, offers to install when visiting panel on mobile devices (HTTPS required) |
No mobile app |
No mobile app |
| Single-Sign-On Support |
SSO provided via LDAP support. Provides group integration so users added to specific LDAP groups are automatically assigned AMP roles. |
No SSO Support |
No SSO Support |
| ARM64/AArch64 Support |
Native AArch64/ARM64 builds available. Supported on Raspberry Pi, Neoverse-N1 and other ARM64 platforms. |
No ARM support. |
