Failed to start AMP. Exit code was 0
OS Name/Version: Fedore 37
Ampinstmgr 2.4.3.4-2
AMP v2.4.4, built 17/05/2023
After installing and completing the AMP setup, everything goes smoothly and to plan. after completing a reboot were see AMP is unable to start any instances including ADS
AMP Service logs
May 23, 2023
11:02 AM
Finished ampinstmgr.service - AMP Instance Manager.
systemd
11:02 AM
[Error] Failed to start AMP. Exit code was 0
ampinstmgr
11:03 AM
Process 1334 (AMP_Linux_x86_6) of user 1000 dumped core. Module /home/amp/.ampdata/instances/ADS01/AMP_Linux_x86_64 with build-id 3d907dfd51def3970966f9333d958f141cb0b2d9 Module /tmp/mono-bundle-y8dhpf/libmonoboehm-2 with build-id ffa713e2049ff10d753792397938018a5f704c87 Module /tmp/mono-bundle-y8dhpf/libmono-native with build-id 424cccd5f4a6ca2103a099ea101b5df63d36b6f7 Module /tmp/mono-bundle-y8dhpf/MonoPosixHelper with build-id 79d773e6b09bd366320ec19858e7654c17740885 Module /tmp/mono-bundle-y8dhpf/libmono-btls-shared with build-id d476a235acd8357c6be855f9d22b4d3ca476bdf1 Module /tmp/mono-bundle-y8dhpf/e_sqlite3 with build-id 6bcc1fa2345785aad27567aa9a689067f40401d0 Module /tmp/mono-bundle-y8dhpf/libsqlite3 with build-id 5e4d89ec762208ca668b4dfac5f761fbdb69e3e6 Module linux-vdso.so.1 with build-id 02d41dea1be42d17709e5c411f68ba964cbe65c3 Module ld-linux-x86-64.so.2 with build-id bb6fec54c7521fddc569a2f4e141dfb97bf3acbe Module libc.so.6 with build-id 81daba31ee66dbd63efdc4252a872949d874d136 Module libgcc_s.so.1 with build-id 6baf7a1f1451ec21c7a598b1ea165a2d563edb07 Module libpthread.so.0 with build-id 622fcaae1f5e94890852b15a1705dff85830347b Module libdl.so.2 with build-id ff36f66b23c53809d27933a667b1f5d6b55e033b Module librt.so.1 with build-id 6080d9df60161f18df8e640eea23089bbc05e13b Module libm.so.6 with build-id 9ca49f056adbf7edc2bda92b95a74d491abe03f2 Stack trace of thread 1334: #0 0x00000000004ad954 n/a (/home/amp/.ampdata/instances/ADS01/AMP_Linux_x86_64 + 0xad954) ELF object binary architecture: AMD x86-64
systemd-coredump
11:03 AM
ampinstmgr
11:03 AM
ampinstmgr
11:03 AM
[Info] AMP Instance Manager v2.4.3.6 built 07/05/2023 12:05
ampinstmgr
11:03 AM
Starting ampinstmgr.service - AMP Instance Manager...
systemd
Once checking the ADS Logs, The logs haven’t updated “Exit code was 0”
  • Install AMP on Fedora 37
  • Complete web interface setup
  • Reboot machine
Attempted to Validate ADS
Force a upgrade with a no-cache flag
Have you checked the logs of the individual instances? You can check them on the command line using ampinstmgr lastlog ADS01 for example.
Hello Mike,
Yes, there last timestamp is from last night during an attempted deployment from the reboot took place,
[20:52:27] [Logger Info]          : Starting AMP version 2.4.4.0 (Decadeus), built 17/05/2023 17:54
[20:52:27] [Logger Info]          : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[20:52:27] [Logger Info]          : Running in a VMware environment.
[20:52:27] [Logger Info]          : OS: Linux / x86_64
[20:52:27] [Logger Info]          : CPU: Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz (10C/10T)
[20:52:27] [Logger Info]          : RAM: 48273MB
[20:52:27] [Logger Info]          : AMP Instance ID: 1995bb39-a112-4c20-98f9-bac112ca5279
[20:52:27] [Logger Info]          : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[20:52:27] [Logger Info]          : Metrics publishing is enabled at udp://10.0.1.4:12820.
[20:52:27] [Logger Info]          : Loaded FileManagerPlugin by CubeCoders Limited
[20:52:27] [Logger Info]          : Loaded EmailSenderPlugin by CubeCoders Limited
[20:52:27] [Logger Info]          : Loaded WebRequestPlugin by CubeCoders Limited
[20:52:27] [Logger Info]          : Loaded LocalFileBackupPlugin by CubeCoders Limited
[20:52:27] [Logger Info]          : Loaded CommonCorePlugin by CubeCoders Limited
[20:52:27] [Logger Info]          : ADSModule requests dependency InstanceManagerPlugin...
[20:52:28] [Logger Info]          : Loaded InstanceManagerPlugin by CubeCoders Limited
[20:52:28] [Logger Info]          : ADSModule requests dependency SystemUserManagerPlugin...
[20:52:28] [Logger Info]          : Loaded SystemUserManagerPlugin by CubeCoders Limited
[20:52:28] [Logger Info]          : Loaded steamcmdplugin by CubeCoders Limited
[20:52:28] [Logger Info]          : Metrics server started OK on port 12820
[20:52:28] [Logger Info]          : ADS startup complete in 143ms
[20:52:28] [Logger Info]          : Updating remote source CubeCoders/AMPTemplates
[20:52:28] [Logger Info]          : Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
[20:52:28] [Logger Notice]        : Using keypair with fingerprint tiKQDkZz2OmRirMd0dde1QF7wqqe94U/Yuy851nQDrs=
[20:52:28] [Logger Info]          : SFTP Server started on 0.0.0.0:2223
[20:52:28] [Webserver Info]       : Websockets are enabled.
[20:52:28] [Logger Info]          : Webserver started on http://0.0.0.0:8080
[20:52:28] [Logger Info]          : RouterTimer@10Hz with 2 jobs started
[20:52:28] [Core Info]            : Checking for AMP updates...
[20:52:29] [Logger Info]          : Startup mode is StartApplication.
[20:52:29] [Core Info]            : AMP is up-to-date.
Already up to date.
[20:52:37] [Logger Activity]      : Authentication attempt for user null from 10.10.0.10
[20:52:37] [Logger Activity]      : Authentication failure for user null from 10.10.0.10 - Failure
[20:53:00] [Logger Activity]      : Authentication attempt for user AMP_SYSTEM from 10.0.1.4
[20:53:00] [Core Activity]        : Authentication success
[20:53:01] [Logger:AMP_SYSTEM Activity] : Changing setting ADSModule.NewInstanceDefaults.DefaultAuthServerURL to https://amp.*******.com/
[20:53:19] [Logger:AMP_SYSTEM Info] : Using cached archive: /home/amp/.ampdata/instances/AMPCache-Mainline-2440.zip
[20:53:21] [InstanceManager:AMP_SYSTEM Info] : docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=AMP_Dev-Lobby01": dial unix /var/run/docker.sock: connect: permission denied.
[20:53:21] [InstanceManager:AMP_SYSTEM Info] : See 'docker run --help'.
[20:53:21] [InstanceManager:AMP_SYSTEM Warning] : Failed to configure new instance Dev-Lobby01 - Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[20:53:21] [Logger:AMP_SYSTEM Error] : Configuration Failed: Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[20:53:21] [Logger:AMP_SYSTEM Warning] : Create Instance Failed: Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:08:21] [Logger:AMP_SYSTEM Info] : Using cached archive: /home/amp/.ampdata/instances/AMPCache-Mainline-2440.zip
[21:08:23] [InstanceManager:AMP_SYSTEM Info] : docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=AMP_Dev-Lobby01": dial unix /var/run/docker.sock: connect: permission denied.
[21:08:23] [InstanceManager:AMP_SYSTEM Info] : See 'docker run --help'.
[21:08:23] [InstanceManager:AMP_SYSTEM Warning] : Failed to configure new instance Dev-Lobby01 - Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:08:23] [Logger:AMP_SYSTEM Error] : Configuration Failed: Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:08:23] [Logger:AMP_SYSTEM Warning] : Create Instance Failed: Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:08:39] [Logger Activity]      : Authentication attempt for user *******from 10.0.1.4
[21:08:39] [Core Activity]        : Authentication success
[21:08:51] [Logger:Anonymous Activity] : Authentication attempt for user *******from 10.0.1.4
[21:08:51] [Logger:Anonymous Activity] : Authentication failure for user *******from 10.0.1.4 - TwoFactorChallenge
[21:09:10] [Logger:AMP_SYSTEM Info] : Using cached archive: /home/amp/.ampdata/instances/AMPCache-Mainline-2440.zip
[21:09:12] [InstanceManager:AMP_SYSTEM Info] : docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=AMP_Dev-Lobby01": dial unix /var/run/docker.sock: connect: permission denied.
[21:09:12] [InstanceManager:AMP_SYSTEM Info] : See 'docker run --help'.
[21:09:12] [InstanceManager:AMP_SYSTEM Warning] : Failed to configure new instance Dev-Lobby01 - Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:09:12] [Logger:AMP_SYSTEM Error] : Configuration Failed: Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:09:12] [Logger:AMP_SYSTEM Warning] : Create Instance Failed: Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:09:17] [Logger Activity]      : Authentication attempt for user ******* from 10.0.1.4
[21:09:17] [Core Activity]        : Authentication success
[21:10:04] [Logger:*******Info]  : Using cached archive: /home/amp/.ampdata/instances/AMPCache-Mainline-2440.zip
[21:10:06] [InstanceManager:*******Info] : docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=AMP_Dev-Lobby01": dial unix /var/run/docker.sock: connect: permission denied.
[21:10:06] [InstanceManager:*******Info] : See 'docker run --help'.
[21:10:06] [InstanceManager:*******Warning] : Failed to configure new instance Dev-Lobby01 - Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:10:06] [Logger:*******Error] : Configuration Failed: Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
[21:10:06] [Logger:*******Warning] : Create Instance Failed: Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
We rebooted to update AMP groups to have DOCKER
What’s the output of ampinstmgr --debug start ADS01?
[root@localhost ~]# su amp
[amp@localhost root]$ ampinstmgr --debug start ADS01
[Debug] Syncing certificate store using /etc/ssl/certs/ca-certificates.crt
[Debug] Current certificate store contains 136 items, system store contains 138
[Debug] Imported 2 certificates.
[Debug] Removed 0 certificates.
[Debug] Sync process completed.
[Debug] Loading instances from /home/amp/.ampdata/instances.json...
[Debug] Loaded 1 instances.
[Debug] Starting process /usr/bin/readlink
[Debug] Arguments: -s -f -n "/home/amp/.ampdata/instances/ADS01"
[Debug] Started process with ID 2448
[Info] Starting Instance: 'ADS01'
[Debug] Started process with ID 2449
[Debug] Fetching metadata for ADS from /opt/cubecoders/amp/shared/Plugins/ADSModule/ADSModule.dll...
[Debug] Fetching metadata for FileManagerPlugin from /opt/cubecoders/amp/shared/Plugins/FileManagerPlugin/FileManagerPlugin.dll...
[Debug] Fetching metadata for EmailSenderPlugin from /opt/cubecoders/amp/shared/Plugins/EmailSenderPlugin/EmailSenderPlugin.dll...
[Debug] Fetching metadata for WebRequestPlugin from /opt/cubecoders/amp/shared/Plugins/WebRequestPlugin/WebRequestPlugin.dll...
[Debug] Fetching metadata for LocalFileBackupPlugin from /opt/cubecoders/amp/shared/Plugins/LocalFileBackupPlugin/LocalFileBackupPlugin.dll...
[Debug] Fetching metadata for CommonCorePlugin from /opt/cubecoders/amp/shared/Plugins/CommonCorePlugin/CommonCorePlugin.dll...
[Debug] Running /usr/bin/tmux -f /dev/null new-session -s "AMP_ADS01" -d "cd '/home/amp/.ampdata/instances/ADS01'; /home/amp/.ampdata/instances/ADS01/AMP_Linux_x86_64 +Core.Webserver.Port "8080" +Core.Webserver.IPBinding "0.0.0.0" +Core.AMP.InstanceID "1995bb39-a112-4c20-98f9-bac112ca5279" +FileManagerPlugin.SFTP.SFTPPortNumber "2223" +ADSModule.Network.MetricsServerPort "12820""
[Debug] Starting process /usr/bin/tmux
[Debug] Working Directory: /home/amp/.ampdata/instances/ADS01
[Debug] Arguments: -f /dev/null new-session -s "AMP_ADS01" -d "cd '/home/amp/.ampdata/instances/ADS01'; /home/amp/.ampdata/instances/ADS01/AMP_Linux_x86_64 +Core.Webserver.Port "8080" +Core.Webserver.IPBinding "0.0.0.0" +Core.AMP.InstanceID "********-****-****-****-************" +FileManagerPlugin.SFTP.SFTPPortNumber "2223" +ADSModule.Network.MetricsServerPort "12820""
[Debug] Started process with ID 2450
[Debug] Started process with ID 2455
[Debug] Started process with ID 2468
[Debug] Started process with ID 2469
[Debug] Started process with ID 2470
[Debug] Started process with ID 2471
[Debug] Started process with ID 2472
[Debug] Started process with ID 2473
[Debug] Started process with ID 2474
[Debug] Started process with ID 2475
[Debug] Started process with ID 2476
[Debug] Started process with ID 2477
[Debug] Started process with ID 2478
[Info] This instance failed to start. Run 'ampinstmgr LastLog ADS01' to view it's most recent log.```
ADS01 logs haven't updated with any new information
![image|690x166](upload://lX5qmuwuOfb8Y4pV0kk6Mb5TnSr.png)
Try again but switch to the amp user with su -l amp rather than just su amp
This gets the same result.
[amp@localhost root]$ su -l amp
Password:
[amp@localhost ~]$ ampinstmgr --debug start ADS01
[Debug] Started process with ID 2746
[Debug] Started process with ID 2747
[Debug] Started process with ID 2748
[Debug] Started process with ID 2753
[Debug] Started process with ID 2770
[Debug] Started process with ID 2772
[Debug] Started process with ID 2773
[Debug] Started process with ID 2774
[Debug] Started process with ID 2775
[Debug] Started process with ID 2776
[Debug] Started process with ID 2777
[Debug] Started process with ID 2778
[Debug] Started process with ID 2779
[Debug] Started process with ID 2780
[Debug] Started process with ID 2781
[Info] This instance failed to start. Run 'ampinstmgr LastLog ADS01' to view it's most recent log.````
You were already the amp user when you did that. Need to exit to root first then switch to the amp user with a login shell
Though probably not the issue at play here
Just to rule it out, SSH into the AMP users and repeat the ampinstmgr --debug start ADS01 but doesn’t produce a different result
Remembered that someone on discord fixed it on fedora 37 by installing some more packages: Discord
This looked promising but hasn’t fixed the issues. dumped the console output in case I missed something but still getting Exit code 0
Last metadata expiration check: 2:45:48 ago on Tue 23 May 2023 09:48:17 AM BST.
Package dnf-utils-4.4.0-1.fc37.noarch is already installed.
Package gtk2hs-buildtools-0.13.8.3-2.fc37.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
[root@localhost ~]#
[root@localhost ~]# dnf groupinstall "Development Tools" "Development Libraries"
Last metadata expiration check: 2:45:53 ago on Tue 23 May 2023 09:48:17 AM BST.
 Package                                     Architecture                               Version                                     Repository                                   Size
Installing Groups:
 Development Tools
Transaction Summary
Is this ok [y/N]: y
Complete!
[root@localhost ~]# su -l amp
[Debug] Started process with ID 3154
[Debug] Started process with ID 3155
[Debug] Started process with ID 3156
[Debug] Started process with ID 3161
[Debug] Started process with ID 3173
[Debug] Started process with ID 3174
[Debug] Started process with ID 3175
[Debug] Started process with ID 3176
[Debug] Started process with ID 3177
[Debug] Started process with ID 3178
[Debug] Started process with ID 3179
[Debug] Started process with ID 3180
[Debug] Started process with ID 3181
[Debug] Started process with ID 3182
[Debug] Started process with ID 3183
[amp@localhost ~]$ ```
