Failed to read manifest as datastore
OS Name/Version: Ubuntu 20.04
Product Name/Version:
AMP
v2.4 9/9/22
I am remote and have limited access to my server please see the screenshot of the error. Happened after a reboot, that i initiated to try to free some resources.
Ive tried to update, upgrade, all of that with no luck just comes back with the same error.
Did the server suffer some kind of unexpected shutdown?
Go to ~/.ampdata/ and you should see a load of instances.json-TIMESTAMP.bak - find the most recent one and copy it to instances.json (overwriting the existing one) and try ampinstmgr status again.
No unexpected reboots, i performed a reboot however as it performed a backup and filled up all the disk space, i deleted that backup and rebooted and it gave me that error afterward.
I restored a backup and it shows the instances working, however it seems like my login doesn’t work, should i try resetting?
Thanks
Ah indeed running out of disk space will cause that problem too.
Yes, you probably need to reset your login.
