ADS instance:
[21:44:58] [ADS:admin Activity] : Managed remote instance Minecraft at http://127.0.0.1:8081/
[21:44:59] [GSMyAdmin:admin Activity] : Authentication token for admin requested by ManageInstance on behalf of admin
Game instance:
[21:45:00] [Core Activity] : Authentication attempt for user admin from 127.0.0.1
[21:45:01] [Core Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected
# Login
Login.UseAuthServer=True
# Login.AuthServerURL - The URL for the ADS instance providing authentication when using UseAuthServer
Login.AuthServerURL=http://127.0.0.1:8080/
Login.MetricsServerPort=12820
Login.UseLDAPLogins=False
Login.LDAPAuthDomain=
Login.LDAPGroupPrefix=AMP_
Avoid âme tooâ posts please without including full information about your setup. This post is a couple of weeks old and AMP has had updates since then.
Dear Mike, did I miss âpleaseâ in your sentence ?
AMP on Unraid server, reinstalled and Minecraft instance re-imported. Only works right click and Manage in new tab.
You did - it was the 4th word. If youâre running a 3rd party Docker container on Unraid thatâs not a supported configuration and you need to contact the image maintainer for any support. We only support Unraid when running in a VM.
Yes, the library issue some people experienced has been fixed. Make sure to follow the âSomething not working on Windowsâ guide from the knowledge base.
Stop AMP fully by running ampinstmgr stopall in a new command prompt.
Use Task Manager to make sure all AMP.exe and AMPService.exe processes are stopped.
Download a fresh copy of AMPSetup.msi - and run it in Repair mode.
Run ampinstmgr --nocache upgradeall in a command prompt.
Reboot the system
I regret to note that I still have the problem with the same error messages in the logs as before:
[11:42:09] [ADS:admin Activity] : Managed remote instance Minecraft at http://127.0.0.1:8081/
[11:42:09] [GSMyAdmin:admin Activity] : Authentication token for admin requested by ManageInstance on behalf of admin
[11:42:11] [Core Activity] : Authentication attempt for user admin from 127.0.0.1
[11:42:12] [Core Activity] : Authentication failure for user admin from 127.0.0.1 - TokenRejected
Iâm happy to try anything else if you have any other suggestions?
