I re-installled AMP yesterday, created an instance and setup 2FA (this was done on my desktop PC). And everything works fine, exept when i try to open an instance on my laptop. because it gives the following Error " Failed to login to remote instance. null" “Two-Factor Login Required”. The thing is, 2FA is enabled, and the server-wide policy is set to optional. So i have no idea why is does not work for my laptop, while my desktop PC and Phone work fine. Also, getting into the main pannel is no problem on my laptop
Step 1: Install AMP on Ubuntu server (fresh install), with anwsering “y” to all options “will you be using docker/java/steamcmd/https”.
yes, i am running in standalone. The log says the following when trying to open an instance:
"[12:37:20] [Logger:Bastiaan Activity] : Managed remote instance SatisfactoryEA01 at http://127.0.0.1:8081/
[12:37:20] [Logger:Bastiaan Activity] : Authentication token for Bastiaan requested by ManageInstance on behalf of Bastiaan".
These 2 lines reoccur everytime i try to open an instance.
[13:13:49] [Logger:Anonymous Activity] : Authentication attempt for user Bastiaan from 127.0.0.1
[13:13:49] [Logger:Anonymous Activity] : Authentication failure for user Bastiaan from 127.0.0.1 - TwoFactorChallenge
Back to Mainstream for now. Disabling 2FA temporarily (or switch to WebAuthn which I don’t think has this problem?) should address the issue in the interim.
