OS Name/Version: Debian 12
Product Name/Version: 2.5
I’m trying to install AMP on my new server, but it seems that my server IP is blacklisted somehow.
This is the error I’m getting when doing a apt update:
Could not connect to repo cubecoders com : 443 (198. 244. 186 . 210), connection timed out
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
W: Failed to fetch https:// repo cubecoders .com/debian/InRelease Could not connect to repo .cubecoders .com:443 (198 . 244 .186 .210), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
I also couldn’t use getamp.sh with wget, I needed to download it on my computer and upload it.
This is the error I’m getting with the installer:
[Activity] Audit: Unknown/None [CreateInstance] Created instance ADS01 using ADS module on port 8080.
[Error] TaskCanceledException
[Error] [0] (TaskCanceledException) : The operation was canceled.
[Error] at ModuleShared.VersionManifest.FetchAsync (String forPlatform)
[Error] SocketException
[Error] [1] (SocketException) : Connection timed out
- Download getamp .sh manually and upload it
- Manually executing getamp .sh file
- Getting error with Connection timed out
Tried to disable IPv6, didn’t work
