Factorio Server SFTP problems
OS Name/Version: Ubuntu 22.04.1
Factorio 1.1.80 - AMP 2.4.3.6
I cannot seem to upload files to my Factorio server. The web interface works, but it it very slow. When I try to connect using SFTP in WinSCP, I just get the message “waiting for Host” until it times out.
provides syntax highlighting.
  • Step 1 - Create a new Factorio instance
  • Step 2 - Start the application
  • Step 3 - Try to upload files via WinSCP
Actions taken to resolve so far: I have tried several different addresses and usernames. I have also checked the AMP config.
Have you verified that the port being used for SFTP is open in the systems firewall?
It seems to be? I am on Oracle Cloud’s infrastructure. How would I do this? Is it through the VCN >> Subnet >> Ingress rules?
Can you connect via localhost on the same system?
What do you mean by “The same system”? It is a remote instance that is running in the cloud somewhere. If you mean “on my computer”, I am not sure how to connect to the instance other than through the Panel or PuTTY. I can gain access on PuTTY and su to “amp”, but I can’t seem to log in as “amp” or my username on WinSCP.
Update 5/15/23:
Fixed the issue! Now I am having another issue: I can log into the server, but it says that I have to sync my modpack as there are no mods on the server. However, I have uploaded the mods, the mods config json, and my modded world. What is going on with that, and how do I fix it?
