Problem Description: I am not able to start my instance suddenly. I restarted my 1U server and now the instance is refusing to start properly. Error code- exit code 32 (NO_LICENCE)
Not sure why suddenly I am getting a no license code.
provides syntax highlighting.
Step 1 - Googled
Step 2 - Searched forums
Step 3 - Tried tracking it down myself no success.
Actions taken to resolve so far: Same steps as reproducing.
OS Name/Version: Windows Server 2019
Product Name/Version: (Always use the full version number - not ‘Latest’) v2.3.4 built 16/6/22
i keep getting this error msg
Instance BinChixken has stopped.
ADS logged stopped instance BinChixken - exit code 32 (NO_LICENCE)
Step 1 i just started server and OS updates and each time i get msg above
Step 2
Step 3
Actions taken to resolve so far: ampinstmgr reactivate ( instance name ) then enter my key again workes until next server restart ( getts annoying )
If you only have the 3+1 instances then you’re fine. It will even out. If you’re past that then you’ll need to buy a new license. I’d recommend the Network Standard.
