OS Name/Version: Windows 10 x64
Product Name/Version: (Always use the full version number - not ‘Latest’) Triton v2.3.4.4
Problem Description: Whenever I try and start an instance I receive the error: exit code 32 (NO_LICENCE).
- Step 1: Start an instance
- Step 2
- Step 3
Googled.
Ran ampinstmgr reactivateall with a developer license.
Ended up reinstalling Windows and resetting up AMP.
Note: I am running AMP through a VPN, and my license key says 55/5 uses since I’m assuming every time I run the reactivate command it adds more.
Are there other ports that need to be forwarded?
Thanks for the help.
Log from the ADS instance:
[17:01:22] [AMPService Info] : Starting AMPService version 2.3.4.4 (Triton), built 26/07/2022 20:08
[17:01:22] [AMPService Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[17:01:22] [GSMyAdmin Warning] : Current time zone is set to Pacific Standard Time - Servers should ideally be UTC to avoid time-zone related issues
[17:01:22] [AMPService Info] : OS: Windows / x86_64
[17:01:22] [AMPService Info] : CPU: AMD Ryzen 5 2600X Six-Core Processor (6C/12T)
[17:01:22] [AMPService Info] : AMP Instance ID: 5c753916-0010-4b18-80fb-184e2cf46ce6
[17:01:23] [GSMyAdmin Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[17:01:23] [GSMyAdmin Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:23] [GSMyAdmin Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:23] [GSMyAdmin Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:23] [GSMyAdmin Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:23] [GSMyAdmin Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[17:01:23] [GSMyAdmin Info] : ADSModule requests dependency InstanceManagerPlugin...
[17:01:24] [GSMyAdmin Info] : Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:24] [GSMyAdmin Info] : ADSModule requests dependency SystemUserManagerPlugin...
[17:01:24] [GSMyAdmin Info] : Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:24] [GSMyAdmin Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[17:01:24] [ADS Info] : Metrics server started OK on port 12820
[17:01:25] [System Info] : Updating remote source CubeCoders/AMPTemplates
[17:01:25] [System Info] : Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
[17:01:25] [FileManager Error] : Failure loading existing SSH keypair.
[17:01:25] [Core Error] : CryptographicException
[17:01:25] [Core Error] : [0] (CryptographicException) : Invalid key format - bad character.
[17:01:25] [Core Error] : at Rebex.Security.Cryptography.Pkcs.PrivateKeyInfo.lxpjx(Byte[] p0, Int32 p1, tzstt& p2, KeyAlgorithm& p3, String& p4)
at Rebex.Security.Cryptography.Pkcs.PrivateKeyInfo.Load(Stream input, String password)
at Rebex.Net.SshPrivateKey.cluhz(Stream p0, String p1)
at FileManagerPlugin.PluginMain.GetKey()
[17:01:25] [FileManager Notice] : No SSH keypair available for embedded server, generating new keypair...
[17:01:25] [FileManager Notice] : Generated new keypair with fingerprint RVYOpDK1nwispA/LctwylYfXwAgDOL+Vbrwqb4sSG+g=
[17:01:25] [GSMyAdmin Notice] : Using keypair with fingerprint RVYOpDK1nwispA/LctwylYfXwAgDOL+Vbrwqb4sSG+g=
[17:01:25] [GSMyAdmin Info] : SFTP Server started on 0.0.0.0:2223
[17:01:25] [GSMyAdmin Info] : Websockets are enabled.
[17:01:26] [GSMyAdmin Info] : Webserver started on http://0.0.0.0:8080
[17:01:26] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[17:01:26] [System Info] : Checking for AMP updates...
Already up to date.
[17:01:26] [System Info] : AMP is up-to-date.
[17:01:30] [System Info] : Waiting for AMP instance to start...
[17:01:31] [System Notice] : AMP instance Bungee is now running.
[17:01:36] [System Info] : Waiting for AMP instance to start...
[17:01:37] [System Notice] : AMP instance Lobby is now running.
[17:01:37] [InstanceManager Activity] : Instance Bungee has stopped.
[17:01:37] [System Info] : ADS logged stopped instance Bungee - exit code 32 (NO_LICENCE)
[17:01:37] [System Info] : Reactivating instance Bungee...
[17:01:38] [System Info] : Waiting for AMP instance to start...
[17:01:38] [System Notice] : AMP instance Bungee is now running.
[17:01:44] [System Info] : Waiting for AMP instance to start...
[17:01:44] [System Notice] : AMP instance Factions is now running.
[17:01:45] [InstanceManager Activity] : Instance Lobby has stopped.
[17:01:45] [System Info] : ADS logged stopped instance Lobby - exit code 32 (NO_LICENCE)
[17:01:45] [System Info] : Reactivating instance Lobby...
[17:01:46] [System Info] : Waiting for AMP instance to start...
[17:01:46] [System Notice] : AMP instance Lobby is now running.
[17:02:00] [InstanceManager Activity] : Instance Factions has stopped.
[17:02:00] [System Info] : ADS logged stopped instance Factions - exit code 32 (NO_LICENCE)
[17:02:00] [System Info] : Reactivating instance Factions...
[17:02:01] [System Info] : Waiting for AMP instance to start...
[17:02:01] [System Notice] : AMP instance Factions is now running.
[17:02:02] [GSMyAdmin Error] : Exception executing global interval tick. Collection was modified; enumeration operation may not execute.
Log from one of the minecraft instances:
[17:01:46] [Program Info] : Starting AMP version 2.3.4.4 (Triton), built 26/07/2022 20:08
[17:01:46] [Program Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[17:01:47] [Core Warning] : Current time zone is set to Pacific Standard Time - Servers should ideally be UTC to avoid time-zone related issues
[17:01:47] [Program Info] : OS: Windows / x86_64
[17:01:47] [Program Info] : CPU: AMD Ryzen 5 2600X Six-Core Processor (6C/12T)
[17:01:47] [Program Info] : AMP Instance ID: 812ca2d5-02eb-4721-8681-85d50dd4c0bb
[17:01:47] [Core Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[17:01:47] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[17:01:47] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:47] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:47] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:47] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[17:01:47] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[17:01:47] [ModuleLoader Notice] : Using keypair with fingerprint gsninT0kSPSlffznEj8e6CvwiY4syoNJb99eQ7/yrwg=
[17:01:47] [ModuleLoader Info] : SFTP Server started on 0.0.0.0:2231
[17:01:47] [Core Error] : No valid AMP licence was found. Please run `ampinstmgr reactivate Lobby` to reactivate this instance.
