Error: Response status code does not indicate success: 429 (Too Many Requests)
OS Name/Version: Debian GNU/Linux 12 LXC on PROXMOX 8.4.14
Product Name/Version: 2.6.3.2 - 20251022.1
Since october 25 when ARMA 3 server auto start/restart AMP gives error 429, update is working fine, manually starting was working with 4 or 5 tries untill today, full error is:
Response status code does not indicate success: 429 (Too Many Requests).
Update:
This seems to be a github error happening on Brazil, maybe on the entire South America, as stated by some people on Reddit: https://www.reddit.com/r/devBR/comments/1oh2hes/github_limitando_downloads_de_usuários_na_américa/ and personaly verified by me trying to run the script to update LXCs from proxmox helper scrips and receiving the same error.
Only workaround possible at the moment is if the Cubecoders devs give us a way to bypass GitHub to start the application.
  • Set automatic restart every 6 hours and a time when the server will be off
  • Notice the error 429 on October 26 and see that it started on October 25
  • Manually tries to start the server until it worked (5 tries needed)
  • October 28 manually intervention stopped working
  • Update AMP controller, target and instance and restarted VM
  • Update and restart Proxmox
  • Manual intervention
Full log below:
[19:39:30] [Program Info/1]       : Starting AMP version 2.6.3.2 (Phobos), built 22/10/2025 11:11
[19:39:30] [Program Info/1]       : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[19:39:30] [Program Info/1]       : Running in a Proxmox LXC Container environment.
[19:39:30] [Program Warning/1]    : Current time zone is set to Brasilia Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[19:39:30] [Program Info/1]       : OS: Linux / x86_64
[19:39:30] [Program Info/1]       : CPU: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz (5C/10T)
[19:39:30] [Program Info/1]       : RAM: 32768MB
[19:39:30] [Program Info/1]       : AMP Instance ID: 4fa32fd0-630d-414a-802c-aac6cc0266a9
[19:39:32] [Core Info/1]          : Loaded GenericModule version 2.6.3.2 by CubeCoders Limited
[19:39:32] [Core Info/1]          : Metrics publishing is enabled at udp://localhost:12820.
[19:39:32] [Loader Info/1]        : Loaded FileManagerPlugin by CubeCoders Limited
[19:39:32] [Loader Info/1]        : Loaded EmailSenderPlugin by CubeCoders Limited
[19:39:32] [Loader Info/1]        : Loaded WebRequestPlugin by CubeCoders Limited
[19:39:32] [Loader Info/1]        : Loaded WebhookPlugin by CubeCoders Limited
[19:39:33] [Loader Info/1]        : Loaded LocalFileBackupPlugin by CubeCoders Limited
[19:39:33] [Loader Info/1]        : Loaded CommonCorePlugin by CubeCoders Limited
[19:39:33] [Loader Info/1]        : Loaded AnalyticsPlugin by CubeCoders Limited
[19:39:33] [Loader Info/1]        : GenericModule requests dependency steamcmdplugin...
[19:39:33] [Loader Info/1]        : Loaded steamcmdplugin by CubeCoders Limited
[19:39:33] [Loader Info/1]        : GenericModule requests dependency RCONPlugin...
[19:39:33] [Loader Info/1]        : Loaded RCONPlugin by CubeCoders Limited
[19:39:33] [Core Info/1]          : Licence Present: AMP Advanced Edition - Lifetime Licence
[19:39:33] [Loader Notice/1]      : Using keypair with fingerprint Di6njauvlMQJmjEGDVTQOuEGjk0sjqcZy/nRC3M1QqM=
[19:39:33] [Loader Info/1]        : SFTP Server started on 0.0.0.0:2224
[19:39:33] [Core Warning/1]       : Schedule trigger d7c42a16-25ef-4aaa-9735-08cb430b180b has a mismatched ID!
[19:39:35] [Core Info/1]          : Webserver started on http://127.0.0.1:8081
[19:39:35] [System Info/10]       : Checking for AMP updates...
[19:39:35] [System Info/9]        : Startup mode is StartApplication.
[19:39:35] [System Info/10]       : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[19:39:35] [Generic Info/9]       : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[19:39:35] [System Info/15]       : AMP is up to date.
[19:39:36] [Core Error/11]        : HttpRequestException
[19:39:36] [Core Error/11]        : [0] (HttpRequestException) : Response status code does not indicate success: 429 (Too Many Requests).
[19:39:36] [Core Error/11]        :    at Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
   at ModuleShared.Utilities.DownloadFileWithProgressAsync(String url, String filename, RunningTask task, Boolean autoRemoveTask, String UserAgent)
[19:49:21] [System Activity/17]   : Authentication attempt for user samueleh from 127.0.0.1
[19:49:22] [System Activity/3]    : Authentication success
[19:49:43] [Core:samueleh Activity/19] : Starting the application.
[19:49:43] [System:samueleh Info/18] : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[19:49:43] [Generic:samueleh Info/19] : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[19:49:44] [Core:samueleh Error/18] : HttpRequestException
[19:49:44] [Core:samueleh Error/18] : [0] (HttpRequestException) : Response status code does not indicate success: 429 (Too Many Requests).
[19:49:44] [Core:samueleh Error/18] :    at Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
[19:49:47] [Core:samueleh Activity/17] : Updating the application.
[19:50:02] [Core:samueleh Activity/19] : Updating the application.
[  0%] Checking for available updates...
UpdateUI: skip show logo
Steam Console Client (c) Valve Corporation - version 1759461699
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "233780"
Logging in using cached credentials.
Logging in user 'samueleudesheinrichs' [U:1:372636398] to Steam Public...OK
Waiting for user info...OK
app_update 233780 -beta public validate
 Update state (0x5) verifying install, progress: 11.68 (629086868 / 5384415733)
 Update state (0x5) verifying install, progress: 24.27 (1306846477 / 5384415733)
 Update state (0x5) verifying install, progress: 36.12 (1945031829 / 5384415733)
 Update state (0x5) verifying install, progress: 48.30 (2600436843 / 5384415733)
 Update state (0x5) verifying install, progress: 60.45 (3254805886 / 5384415733)
 Update state (0x5) verifying install, progress: 72.92 (3926090005 / 5384415733)
 Update state (0x5) verifying install, progress: 85.29 (4592372305 / 5384415733)
 Update state (0x5) verifying install, progress: 96.77 (5210665528 / 5384415733)
Success! App '233780' fully installed.
quit
Unloading Steam API...OK
[19:50:29] [System:samueleh Info/18] : SteamCMD Update successful
[19:50:29] [System:samueleh Info/18] : Downloading steam workshop items...
[19:50:29] [System:samueleh Info/18] : Downloading items 450814997,463939057,3283642267,2291129343,2992224248...
workshop_download_item 107410 450814997 validate
Downloading item 450814997 ...
Success. Downloaded item 450814997 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/450814997" (4648405 bytes) workshop_download_item 107410 463939057 validate
Downloading item 463939057 ...
Success. Downloaded item 463939057 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/463939057" (227199182 bytes) workshop_download_item 107410 3283642267 validate
Downloading item 3283642267 ...
Success. Downloaded item 3283642267 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/3283642267" (42869480 bytes) workshop_download_item 107410 2291129343 validate
Downloading item 2291129343 ...
Success. Downloaded item 2291129343 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2291129343" (530524003 bytes) workshop_download_item 107410 2992224248 validate
Downloading item 2992224248 ...
Success. Downloaded item 2992224248 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2992224248" (99556356 bytes) quit
[19:50:40] [System:samueleh Info/9] : SteamCMD Update successful
[19:50:40] [System:samueleh Info/9] : Downloading items 884372152,1808238502,1858070328,1858075458,583496184...
workshop_download_item 107410 884372152 validate
Downloading item 884372152 ...
Success. Downloaded item 884372152 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/884372152" (1587894 bytes) workshop_download_item 107410 1808238502 validate
Downloading item 1808238502 ...
Success. Downloaded item 1808238502 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/1808238502" (36766 bytes) workshop_download_item 107410 1858070328 validate
Downloading item 1858070328 ...
Success. Downloaded item 1858070328 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/1858070328" (46153 bytes) workshop_download_item 107410 1858075458 validate
Downloading item 1858075458 ...
Success. Downloaded item 1858075458 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/1858075458" (1377860 bytes) workshop_download_item 107410 583496184 validate
Downloading item 583496184 ...
Success. Downloaded item 583496184 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/583496184" (11751310970 bytes) quit
[19:50:54] [System:samueleh Info/18] : SteamCMD Update successful
[19:50:54] [System:samueleh Info/18] : Downloading items 2648308937,2012417505,2710902874,2946868556,820924072...
workshop_download_item 107410 2648308937 validate
Downloading item 2648308937 ...
Success. Downloaded item 2648308937 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2648308937" (16836635001 bytes) workshop_download_item 107410 2012417505 validate
Downloading item 2012417505 ...
Success. Downloaded item 2012417505 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2012417505" (406588618 bytes) workshop_download_item 107410 2710902874 validate
Downloading item 2710902874 ...
Success. Downloaded item 2710902874 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2710902874" (338562848 bytes) workshop_download_item 107410 2946868556 validate
Downloading item 2946868556 ...
Success. Downloaded item 2946868556 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2946868556" (2172857 bytes) workshop_download_item 107410 820924072 validate
Downloading item 820924072 ...
Success. Downloaded item 820924072 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/820924072" (122969 bytes) quit
[19:51:05] [System:samueleh Info/18] : SteamCMD Update successful
[19:51:05] [System:samueleh Info/18] : Downloading items 2190826124,3226850988,2800081814,3283652320,2127693591...
workshop_download_item 107410 2190826124 validate
Downloading item 2190826124 ...
Success. Downloaded item 2190826124 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2190826124" (10321745 bytes) workshop_download_item 107410 3226850988 validate
Downloading item 3226850988 ...
Success. Downloaded item 3226850988 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/3226850988" (114630584 bytes) workshop_download_item 107410 2800081814 validate
Downloading item 2800081814 ...
Success. Downloaded item 2800081814 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2800081814" (392338 bytes) workshop_download_item 107410 3283652320 validate
Downloading item 3283652320 ...
Success. Downloaded item 3283652320 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/3283652320" (159337334 bytes) workshop_download_item 107410 2127693591 validate
Downloading item 2127693591 ...
Success. Downloaded item 2127693591 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2127693591" (342894 bytes) quit
[19:51:18] [System:samueleh Info/18] : SteamCMD Update successful
[19:51:18] [System:samueleh Info/18] : Downloading items 894678801,1480333388,333310405,1638341685,3283645995...
workshop_download_item 107410 894678801 validate
Downloading item 894678801 ...
Success. Downloaded item 894678801 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/894678801" (85999443 bytes) workshop_download_item 107410 1480333388 validate
Downloading item 1480333388 ...
Success. Downloaded item 1480333388 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/1480333388" (12871 bytes) workshop_download_item 107410 333310405 validate
Downloading item 333310405 ...
Success. Downloaded item 333310405 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/333310405" (628454 bytes) workshop_download_item 107410 1638341685 validate
Downloading item 1638341685 ...
Success. Downloaded item 1638341685 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/1638341685" (1751870 bytes) workshop_download_item 107410 3283645995 validate
Downloading item 3283645995 ...
Success. Downloaded item 3283645995 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/3283645995" (51119642 bytes) quit
[19:51:30] [System:samueleh Info/18] : SteamCMD Update successful
[19:51:30] [System:samueleh Info/18] : Downloading items 2691430448,2012371414,1399447232,1496363537,3127461009...
workshop_download_item 107410 2691430448 validate
Downloading item 2691430448 ...
Success. Downloaded item 2691430448 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2691430448" (6100322197 bytes) workshop_download_item 107410 2012371414 validate
Downloading item 2012371414 ...
Success. Downloaded item 2012371414 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2012371414" (527580448 bytes) workshop_download_item 107410 1399447232 validate
Downloading item 1399447232 ...
Success. Downloaded item 1399447232 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/1399447232" (1459307539 bytes) workshop_download_item 107410 1496363537 validate
Downloading item 1496363537 ...
Success. Downloaded item 1496363537 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/1496363537" (127347268 bytes) workshop_download_item 107410 3127461009 validate
Downloading item 3127461009 ...
Success. Downloaded item 3127461009 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/3127461009" (192270 bytes) quit
[19:51:43] [System:samueleh Info/18] : SteamCMD Update successful
[19:51:43] [System:samueleh Info/18] : Downloading items 2915485125...
workshop_download_item 107410 2915485125 validate
Downloading item 2915485125 ...
Success. Downloaded item 2915485125 to "/home/amp/.ampdata/instances/Arma301/arma3/233780/steamapps/workshop/content/107410/2915485125" (81129853 bytes) quit
[19:51:49] [System:samueleh Info/18] : SteamCMD Update successful
[19:51:55] [System:samueleh Info/9] : Skipping download - target already exists (/home/amp/.ampdata/instances/Arma301/arma3/233780/AMP_server.cfg)
[19:51:56] [System:samueleh Info/9] : Skipping download - target already exists (/home/amp/.ampdata/instances/Arma301/arma3/233780/basic.cfg)
[19:51:57] [Core:samueleh Error/9] : HttpRequestException
[19:51:57] [Core:samueleh Error/9] : [0] (HttpRequestException) : Response status code does not indicate success: 429 (Too Many Requests).
[19:51:57] [Core:samueleh Error/9] :    at Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
[19:52:33] [Core:samueleh Activity/10] : Starting the application.
[19:52:33] [System:samueleh Info/9] : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[19:52:33] [Generic:samueleh Info/10] : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[19:52:34] [Core:samueleh Error/16] : HttpRequestException
[19:52:34] [Core:samueleh Error/16] : [0] (HttpRequestException) : Response status code does not indicate success: 429 (Too Many Requests).
[19:52:34] [Core:samueleh Error/16] :    at Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
[19:54:24] [Core:samueleh Activity/16] : Starting the application.
[19:54:24] [System:samueleh Info/10] : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[19:54:24] [Generic:samueleh Info/16] : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[19:54:25] [Core:samueleh Error/20] : HttpRequestException
[19:54:25] [Core:samueleh Error/20] : [0] (HttpRequestException) : Response status code does not indicate success: 429 (Too Many Requests).
[19:54:25] [Core:samueleh Error/20] :    at Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
[19:55:17] [Core:samueleh Activity/23] : Starting the application.
[19:55:17] [System:samueleh Info/16] : Merging config file ./arma3/233780/server.cfg (Template) using Unicode (UTF-8) encoding.
[19:55:17] [Generic:samueleh Info/23] : Writing config file ./arma3/233780/battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[19:55:19] [Core:samueleh Error/20] : HttpRequestException
[19:55:19] [Core:samueleh Error/20] : [0] (HttpRequestException) : Response status code does not indicate success: 429 (Too Many Requests).
[19:55:19] [Core:samueleh Error/20] :    at Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
Nice sleuthing
AMP depends on GitHub downloads for the instance templates as well as components of them (like in Arma 3’s case, scripts to handle mods and headless clients)
Can you confirm that the issue is limited to raw.githubusercontent.com, and not github.com itself?
If so, there is a workaround that can be implemented in AMP
Edit: Further testing shows that requests for raw files from github.com are redirect to raw.githubusercontent.com anyway, so this may not resolve the issue
This don’t work anymore: “4 or 5 tries untill today“
Now is inpossible to start the server using AMP.
What i do?
I log in Linux using terminal, i go to the server folder, and i start the server manualy.
At least i’m finally learning some Linux so i can do all my self.
Greelan is already working on a fix to work around the issues caused by GitHub. No need to chime in unless you have something constructive to add.
Thanks for @Greelan and @IceOfWraith for noticing and working on the problem, even with my ticket being kind of a duplicate. I noticed some users being mean, and other problems, and choose to try to easy the devs lifes.
Just to doccument: this problem seems to extend to entire Latim America, as stated by users from Argentina and Chile in this post: https://www.reddit.com/r/github/comments/1ofou5i/429_too_many_requests/
Just to check: is GitHub giving erros all around the world or just in Latim America?
Starting the script manualy do start headless client to?
I use linux daily, but I just don’t want to manage Arma 3 manually as it allways has been a headache ;-;
I will resolve to this on this weekend if necessary.
@Greelan seems that the GitHub service is working for me and my friends from other states, I don’t know if is just intermittently back on or they solve their issues. Do I wait to mark this ticket as solved?
I’ve made one tweak to the Arma template so that it downloads the required files directly rather than relying on redirects. Whether that helps is unclear
If it is just that GH for whatever reason has decided to become overly restrictive in Sth America, there will have to be a longer term alternative solution in AMP to avoid hitting those new limits
Good that it seems to work for you now, at least for the time being xD
That was quick!
Thanks for addressing the problem, I will be looking into reporting and docummenting bugs to help improve your produc as your dev team seems so suportive.
