Error Forge 1.7.10 + Cauldron
I can’t run Cauldron, it gives me this error.
Failed to load user banlist: java.io.FileNotFoundException: banned-players.json (No such file or directory)
Failed to load operators list: java.io.FileNotFoundException: ops.json (No such file or directory)
However, these files do exist! Can anyone help me? I wanted to add plugins to a Forge 1.7.10 server, but it seems impossible =c
Thank you.
Please provide the full log, small snippets are useless. (I run Cauldron fine in my own setup)
I try to make a version with cauldron on my computer, and I succeed.
But the service provider where I have the server hosted simply gives me this error, when I start the server.
The server logs folder is empty.
I did exactly as I did on my machine but it doesn’t work.
Is there a video on how to do it?
I appreciate your help.
Make sure you have Java 8 selected under Java and Memory
Then just share whatever is in the console if there’s no log.
Yes, I had Java 8, but it didn’t work. Now I’ve made a newer version of Minecraft and it works without any problems… It’s a shame I can’t get it to work with version 1.7.10.
By the way, how do I get it to start with a .bat file instead of a .jar file? I can’t do it.
AMP doesn’t support .bat files due to security concerns, you can use the Custom server type, however it’s rarely needed as you can just select the other Jar.
