**Interface saying ‘’**AMP is not currently running’’
Tried restarting Amp ADS01
Tried Updating AMP
Tried repairing AMP
Last log of ADS01 says the following: Any help would be appreciated.
[12:34:21] [Core Info/5] : Starting AMPService version 2.8.0.4 (Proteus), built 24/07/2026 17:14
[12:34:21] [Core Info/5] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[12:34:21] [Core Warning/7] : Current time zone is set to AUS Eastern Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[12:34:21] [Core Info/7] : OS: Windows / x86_64
[12:34:21] [Core Info/7] : CPU: AMD Ryzen 5 5600X 6-Core Processor (6C/12T)
[12:34:21] [Core Info/7] : RAM: 32671MB
[12:34:21] [Core Info/7] : AMP Instance ID: 1952868d-9789-4df7-9f67-9736a942d890
[12:34:21] [Core Info/7] : Loaded ADSModule version 2.8.0.4 by CubeCoders Limited
[12:34:21] [Core Warning/7] : Unable to set field value for node: SFTPServerSettings.SFTPPortNumber to 2223 - Attempted to access a missing method.
[12:34:21] [Core Info/7] : Loaded FileManagerPlugin by CubeCoders Limited
[12:34:21] [Core Info/7] : Loaded EmailSenderPlugin by CubeCoders Limited
[12:34:21] [Core Info/7] : Loaded WebRequestPlugin by CubeCoders Limited
[12:34:21] [Core Info/7] : Loaded WebhookPlugin by CubeCoders Limited
[12:34:21] [Core Info/7] : Loaded CommonCorePlugin by CubeCoders Limited
[12:34:21] [Core Info/7] : Loaded StorePlugin by StorePlugin
[12:34:21] [Core Info/7] : ADSModule requests dependency InstanceManagerPlugin…
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance ADS01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance SexDungeonGamers03: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance TheLordoftheRingsReturntoMoria01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance S7D2DServer01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance SexDungeonGamersValheim01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance SexDungeonGamersCononExiles01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance Drangonwilds01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance Windrose01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance CloudMist01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance ShiftingSands01: Attempted to access a missing method.
[12:34:21] [InstanceManager Warning/7] : Failed to repair PortList for instance ConanExilesEnhanced01: Attempted to access a missing method.
[12:34:21] [Core Info/7] : Loaded InstanceManagerPlugin by CubeCoders Limited
[12:34:21] [Core Info/7] : ADSModule requests dependency SystemUserManagerPlugin…
[12:34:21] [Core Info/7] : Loaded SystemUserManagerPlugin by CubeCoders Limited
[12:34:21] [Core Info/5] : Loaded steamcmdplugin by CubeCoders Limited
[12:34:21] [Core Info/5] : Metrics server started OK on port 12820
[12:34:21] [ADS Info/5] : ADS startup complete in 31ms
[12:34:21] [ADS Info/13] : Updating remote source CubeCoders/AMPTemplates:main
[12:34:21] [ADS Info/13] : Updating existing remote source GitHub - CubeCoders/AMPTemplates: For the AMP community to share Generic Module templates. · GitHub …
No stash entries found.
[12:34:21] [FileManager Notice/5] : Using keypair with fingerprint EG870RglJMJdiFs/R+JrlzT61wDmpI1Ti62OT41CipQ=
[12:34:21] [FileManager Info/5] : SFTP Server started on 0.0.0.0:2223
