Enshrouded wont start on Proxmox VM
OS Name/Version: Ubuntu 22.04.5 LTS
Product Name/Version: AMP Release “Phobos” v2.6.0.12
Upon fresh install of Enshrouded, server hangs with message " Started Thread With Stack Range) but will not load or go any further.
  • Install AMP on Proxmox Virtual Machine
  • Install instance of Enshrouded
  • Observe Console for problem
Changed CPU type in proxmox to Host
Tried instance of Rust which does work
Tried pterodactyl panel which enshrouded still produces same problem
I am to assume the problem is related to Enshrouded specifically running on a virtual machine because it ran fine on the main server and rust runs fine on the virtual machine.
Run this as root:
bash -c 'echo "vm.max_map_count = 16777216" > /etc/sysctl.d/20-max_map_count.conf && sysctl --system'
I ran this command with no luck and even changed the CPU type to host still with no luck. still gives me the same message and hangs up on:
Machines:
[os] Started thread 0x000000001adbfdb8 (Session) with stack range (0x00000000231c0000-0x00000000232c0000 size:1,048,576)
[os] Started thread 0x000000000e1b0fa8 (P2pReceiveThread) with stack range (0x000000001afc0000-0x000000001b0c0000 size:1,048,576)
[os] Started thread 0x000000002becfee8 (HttpClient) with stack range (0x0000000033ed0000-0x0000000033fd0000 size:1,048,576)
[os] Started thread 0x00000000231bfdc8 (GameServer) with stack range (0x00000000341d0000-0x00000000342d0000 size:1,048,576)
[os] Started thread 0x00000000231bfd98 (HttpClient) with stack range (0x00000000340d0000-0x00000000341d0000 size:1,048,576)
[os] Started thread 0x00000000231bf4f0 (SaveData) with stack range (0x0000000033fd0000-0x00000000340d0000 size:1,048,576)
