Enshrouded Triggers Not Working
OS Name/Version:
┃ Key                  ┃ Value                               ┃
┃ Operating System     ┃ Windows - Windows 10 Home on x86_64 ┃
┃ Product              ┃ AMP 'Decadeus' v2.4.8.0 (Mainline)  ┃
┃ Virtualization       ┃ None                                ┃
┃ Application          ┃ Enshrouded                          ┃
┃ Module               ┃ GenericModule                       ┃
┃ Running in Container ┃ No                                  ┃
┃ Current State        ┃ Stopped                             ┃
I have a trigger that stops the app, takes a backup, updates the app, then restarts the app.
When the trigger fires, the following message is displayed: This task could not be completed: Stopping Enshrouded… - - State: 3.
Application stopped unexpectedly with exit code 0.
And the trigger halts. I have to manually restart the application and make a manual copy of the game save files as the manual backup function also fails to make a backup.
  • Create a trigger at 11am UDT with 4 steps. Mine is stop app, take backup, update app, restart app.
  • Wait for trigger to fire.
  • Error window is thrown, halting trigger progress. Clear window.
I’ve deleted and re-created the trigger several times and I’ve tried taking a manual backup multiple times. The “building file list…” window pops up, then goes away. No backups created.
