Enshrouded Stuck on starting
OS Name/Version:Debian GNU/Linux 12
Product Name/Version: Enshrouded
[I 00:00:01,037] [enshrouded] Create logfile
[I 00:00:01,038] enshrouded_server(detached HEAD) - version cb9ad30f66287e3a53e6e082ede4ad7950298b81 (master)
[I 00:00:01,038] CPUs:
[I 00:00:01,041]  Idx   Id  Group  LogIdx  CoreIdx  LLCIdx  NumaIdx  EffClass
[I 00:00:01,041]   0   256    0       0        0       3       0        0
[I 00:00:01,042]   1   257    0       1        1       3       0        0
[I 00:00:01,042] CPU Types:
[I 00:00:01,044]   LPerformance:   2   0000000000000000000000000000000000000000000000000000000000000011
[I 00:00:01,044]   PPerformance:   2   0000000000000000000000000000000000000000000000000000000000000011
[I 00:00:01,045]   LEfficient:     0   0000000000000000000000000000000000000000000000000000000000000000
[I 00:00:01,045] [task] TaskSystemSetup:
[I 00:00:01,045] [task]   mainWorkerCount: 2
[I 00:00:01,045] [task]   Group 'Default'  worker:3  main:2
[I 00:00:01,045] [task]      0:  Task-Default00  0000000000000000000000000000000000000000000000000000000000000000
[I 00:00:01,046] [task]      1:  Task-Default01  0000000000000000000000000000000000000000000000000000000000000000
[I 00:00:01,046] [task]      2:  Task-Default02  0000000000000000000000000000000000000000000000000000000000000011
[I 00:00:01,047] [task]   Group 'Background'  worker:1  main:0
[I 00:00:01,047] [task]      0:  Task-Background00  0000000000000000000000000000000000000000000000000000000000000011
[I 00:00:01,047] [app] start creation step Init
[I 00:00:01,047] [app] start creation step Init_Steamworks
[I 00:00:01,053] [os] Started thread 0x00000000023dc710 (Task-Default02) with stack range (0x000000000c0b0000-0x000000000c4b0000 size:4,194,304)
[I 00:00:01,061] [os] Started thread 0x00000000022dc5d0 (Task-Background00) with stack range (0x000000000c4b0000-0x000000000c8b0000 size:4,194,304)
[I 00:00:01,838] [app] start creation step Init_ResourceSystem
[I 00:00:01,838] [os] 'QueryIoRingCapabilities' failed with error 0x80004001 - IORing not available
[I 00:00:01,838] [os] Using platform specific Async I/O implementation!
[I 00:00:01,843] [resource] Loaded kfc file 'Z:/AMP/enshrouded/2278520/enshrouded_server.kfc' with 31,865 resources.
[I 00:00:01,893] [os] Started thread 0x00000000025dcea0 (SteamworksSystem) with stack range (0x000000000c8b0000-0x000000000c9b0000 size:1,048,576)
[I 00:00:01,934] [resource] Using MB(0x0000000000000000:0) as graphics upload buffer
[I 00:00:02,051] [os] Using IOCP API for async io queue 'ResourceContent' (buffers:1 max-command-count:64)
[I 00:00:02,051]
[I 00:00:02,073] [os] Started thread 0x00000000031b9fc8 (AsyncIo-IOCP) with stack range (0x00000000196c0000-0x00000000197c0000 size:1,048,576)
[I 00:00:02,074] [os] Started thread 0x00000000025de4f8 (ResourceContent) with stack range (0x00000000195c0000-0x00000000196c0000 size:1,048,576)
[I 00:00:06,063] [resource] Loaded 212,163,800 bytes of resource data in 4.01 s
[I 00:00:06,102] [app] start creation step Init_ResourcePreload_Start
[I 00:00:06,104] [app] start creation step Init_ResourcePreload_Wait
[I 00:00:06,107] [resource] Preload of 0 bytes finished after 584.00 us (0.00 MiB/s)
[I 00:00:06,107] [app] start creation step Init_Version
[I 00:00:06,108] Game Version (SVN): 654213
[I 00:00:06,108] [app] start creation step Init_UserSystem
[W 00:00:06,109] [user] Couldn't retrieve steam friends interface.
[W 00:00:06,109] [user] Couldn't retrieve steam user interface.
[I 00:00:06,109] [app] start creation step Init_OnlineSystem
[I 00:00:06,125] [OnlineProviderSteam] started transition from 'Uninitialized' to 'Initialized' (current='<invalid>')!
[I 00:00:06,155] [os] Started thread 0x000000000c9b0e78 (P2pReceiveThread) with stack range (0x00000000197c0000-0x00000000198c0000 size:1,048,576)
[I 00:00:06,157] [os] Started thread 0x000000000c9b0ea8 (P2pSendThread) with stack range (0x00000000198c0000-0x00000000199c0000 size:1,048,576)
[I 00:00:06,161] [app] start creation step Init_Session
[I 00:00:06,163] [app] start creation step Init_Tracking
[I 00:00:06,164] [app] start creation step Init_SaveDataSystem
[E 00:00:06,165] [savedata] Couldn't retrieve steam remote storage interface.
[W 00:00:06,165] [savedata] Steam Cloud is disabled.
[I 00:00:06,190] [os] Started thread 0x000000002a6c40b0 (HttpClient) with stack range (0x00000000326d0000-0x00000000327d0000 size:1,048,576)
[I 00:00:06,200] [app] start creation step Load_ResourceObject
[I 00:00:06,201] [app] start creation step Init_TwitchDrops
[I 00:00:06,202] [app] start creation step Init_ServerThread
[I 00:00:06,202] [app] start creation step StartGame
[I 00:00:06,203] [app] start creation step Init
[I 00:00:06,204] [app] start creation step StartGame
[I 00:00:06,205] -------------- Session ----------------
[I 00:00:06,213] [os] Started thread 0x000000000c9b0ef8 (Session) with stack range (0x00000000219c0000-0x0000000021ac0000 size:1,048,576)
[I 00:00:06,221] [Session] started transition from 'Lobby' to 'Host_Online' (current='<invalid>')!
[I 00:00:06,221] [Session] 'PrepareGame' (up)!
[I 00:00:06,227] Machines:
[I 00:00:06,227] [os] Started thread 0x000000002a6cc510 (SaveData) with stack range (0x00000000327d0000-0x00000000328d0000 size:1,048,576)
[I 00:00:06,228] ---------------------------------------
[I 00:00:06,245] [os] Started thread 0x000000002a6cfd38 (HttpClient) with stack range (0x00000000328d0000-0x00000000329d0000 size:1,048,576)
[I 00:00:06,249] [os] Started thread 0x000000002a6cfd68 (GameServer) with stack range (0x00000000329d0000-0x0000000032ad0000 size:1,048,576)
  • Installed Enshrouded
  • Loaded up
  • Server just loops starting
Fresh install and searched for answers
Hey Liam,
I am also running debian 12 server, and an enshrouded server. I had some issues with steamcmd. you mentioned removing the instances and recreated it. Did you reboot the server? I had to reboot and let AMP processes startup and then recreated the Enshrouded Instance.
