It does not display anything when enabled. Running Purpur latest. Is there only certain servers it works with?
Yes, it works with servers that respond to the /tps command out of the box and reply in a format/syntax that AMP recognises. So AMP will show the metric if it’s available.
What servers does that include? I have a 1.15 paper server that works with tps while a newer 1.18 purpur/paper server doesnt appear to work.
There’s not a fixed list of servers that are supported. AMP tries to run the tps command, and if it gets a response back that it recognises then the value is shown. Otherwise it doesn’t show it.
