Editing port bindings throws exception
OS Name/Version: Linux Debian 10 / Windows 10
Product Name/Version: AMP 2.3.3
Attempting to modify port bindings (Eg. adding RCON port) throws exception NullReferenceException.
Using Debian 10 as the management instance and Windows 10 as an target instance.
20:28:17
Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of Backbite
20:28:27
Managed remote instance VRising01 at http://192.168.1.178:8081/
Authentication token for Backbite requested by ManageInstance on behalf of Backbite
20:28:49
Returned exception from API call ADSModule/ModifyCustomFirewallRule
[0] (NullReferenceException) : Object reference not set to an instance of an object
at ADSModule.WebMethods.ModifyCustomFirewallRule (Guid instanceId, Int32 PortNumber, Int32 Range, ModuleShared.PortProtocol Protocol, String Description, Boolean Open) at GSMyAdmin.WebServer.WebAttributes.InvokeMethod (String MethodName, Newtonsoft.Json.Linq.JObject Data, m.Http.IHttpRequest request, ModuleShared.IWebSession Session, ModuleShared.WebMethodsBase MethodsClass, String RawRequest) at GSMyAdmin.WebServer.APIService.InvokeAPI (m.Http.IHttpRequest request, ModuleShared.IWebSession Session, Newtonsoft.Json.Linq.JObject Data, String RequestModule, String RequestMethod, String RawRequest)
20:30:53
  • Step 1 - Right click server instance
  • Step 2 - Edit port bindings
  • Step 3 - Enter data for new port
  • Step 4 - Click the plus to add the rule
  • Going directly to the instance and adding the port mapping works.
Sorry for being so shameless, but would you say that’s the same problem as mine?
It’s a known issue that controllers can’t change the settings of instances on remote targets right now, for the time being you need to log into the target to change ports/settings/etc.
