EDIT: got it running
i restarted host server
made sure valheim+ config is in sync as well
copied all mods from valheimplus ValheimPlus | Thunderstore - The Valheim Mod Database to server
- Tried migrated world save with all currently locally hosted BepInEx Mods (valheimplus + longshipupgrades + equipmentandquickslots + zensign[works clientonly as well]) => failed to start server
- Removed plugin by plugin - in the end only valheim plus was locally used (and saved)
3.also tried new instance with new world without valheimplus & bepinex - got fresh instance/and server+world starting but failed to connect with my client
My goal is to migrate a so far locally hosted valheim world to my dedicated ubuntu server managed with heimdall and AMP.
With my migrated world and mods (even just valheimplus) my world fails to start.
If i create a new instance without any mods and without world migration, the server starts but I cant conenct with my valheim. Tried both with vanilla and valheimplus enabled on both sides (server and client).
I’ve validated that the ports are indeed open to the public!
I’ve uploaded my locally and to be migrated world saves, via this instance’s SFTP Account to the (instance)/Saves/ dir.
#BepInEx LogOutput Steps 1-2
[Message: BepInEx] BepInEx 5.4.22.0 - valheim_server (05/05/2025 19:17:28)
[Message: BepInEx] User is running BepInExPack Valheim version 5.4.2202 from Thunderstore
[Info : BepInEx] Running under Unity vUnknown (post-2017)
[Info : BepInEx] CLR runtime version: 4.0.30319.42000
[Info : BepInEx] Supports SRE: True
[Info : BepInEx] System platform: Bits64, Linux
[Message: BepInEx] Preloader started
[Info : BepInEx] Loaded 1 patcher method from [BepInEx.Preloader 5.4.22.0]
[Info : BepInEx] 1 patcher plugin loaded
[Info : BepInEx] Patching [UnityEngine.CoreModule] with [BepInEx.Chainloader]
[Message: BepInEx] Preloader finished
[Info : BepInEx] Detected Unity version: v2022.3.50f1
[Message: BepInEx] Chainloader ready
[Message: BepInEx] Chainloader started
[Info : BepInEx] 2 plugins to load
[Info : BepInEx] Loading [Valheim Plus 0.9.16.2]
[Info :Valheim Plus] Valheim game version: l-0.220.5
[Info :Valheim Plus] Valheim Plus full version: 0.9.16.2
[Info :Valheim Plus] Valheim Plus dll file location: ‘/AMP/Valheim/896660/BepInEx/plugins/ValheimPlus.dll’
[Info :Valheim Plus] Trying to load the configuration file
[Info :Valheim Plus] Found config file at: ‘/AMP/Valheim/896660/BepInEx/config/valheim_plus.cfg’
[Info :Valheim Plus] Loading config…
[Info :Valheim Plus] [AdvancedBuildingMode] Section is NOT enabled.
[Info :Valheim Plus] [AdvancedEditingMode] Section is NOT enabled.
[Info :Valheim Plus] [Armor] Section is NOT enabled.
[Info :Valheim Plus] [AutoStack] Section is NOT enabled.
[Info :Valheim Plus] [Bed] Section is enabled.
[Info :Valheim Plus] [Bed] Updating sleepWithoutSpawn from False to True
[Info :Valheim Plus] [Bed] Done with section.
[Info :Valheim Plus] [Beehive] Section is NOT enabled.
[Info :Valheim Plus] [Brightness] Section is NOT enabled.
[Info :Valheim Plus] [Building] Section is NOT enabled.
[Info :Valheim Plus] [Camera] Section is NOT enabled.
[Info :Valheim Plus] [Chat] Section is NOT enabled.
[Info :Valheim Plus] [CraftFromChest] Section is enabled.
[Info :Valheim Plus] [CraftFromChest] Updating range from 20 to 40
[Info :Valheim Plus] [CraftFromChest] Updating disableCookingStation from False to True
[Info :Valheim Plus] [CraftFromChest] Done with section.
[Info :Valheim Plus] [Deconstruct] Section is NOT enabled.
[Info :Valheim Plus] [Demister] Section is NOT enabled.
[Info :Valheim Plus] [Durability] Section is NOT enabled.
[Info :Valheim Plus] [EitrRefinery] Section is NOT enabled.
[Info :Valheim Plus] [EitrUsage] Section is NOT enabled.
[Info :Valheim Plus] [Experience] Section is NOT enabled.
[Info :Valheim Plus] [Fermenter] Section is NOT enabled.
[Info :Valheim Plus] [FireSource] Section is enabled.
[Info :Valheim Plus] [FireSource] Updating torches from False to True
[Info :Valheim Plus] [FireSource] Done with section.
[Info :Valheim Plus] [FirstPerson] Section is NOT enabled.
[Info :Valheim Plus] [Food] Section is NOT enabled.
[Info :Valheim Plus] [FreePlacementRotation] Section is NOT enabled.
[Info :Valheim Plus] [Furnace] Section is NOT enabled.
[Info :Valheim Plus] [Game] Section is NOT enabled.
[Info :Valheim Plus] [GameClock] Section is enabled.
[Info :Valheim Plus] [GameClock] Done with section.
[Info :Valheim Plus] [Gathering] Section is NOT enabled.
[Info :Valheim Plus] [GridAlignment] Section is enabled.
[Info :Valheim Plus] [GridAlignment] Done with section.
[Info :Valheim Plus] [HealthUsage] Section is NOT enabled.
[Info :Valheim Plus] [Hotkeys] Section is enabled.
[Info :Valheim Plus] [Hotkeys] Done with section.
[Info :Valheim Plus] [HotTub] Section is NOT enabled.
[Info :Valheim Plus] [Hud] Section is enabled.
[Info :Valheim Plus] [Hud] Updating showRequiredItems from False to True
[Info :Valheim Plus] [Hud] Updating experienceGainedNotifications from False to True
[Info :Valheim Plus] [Hud] Updating displayBowAmmoCounts from 0 to 1
[Info :Valheim Plus] [Hud] Done with section.
[Info :Valheim Plus] [Inventory] Section is enabled.
[Info :Valheim Plus] [Inventory] Updating mergeWithExistingStacks from False to True
[Info :Valheim Plus] [Inventory] Updating playerInventoryRows from 4 to 6
[Info :Valheim Plus] [Inventory] Updating woodChestColumns from 5 to 6
[Info :Valheim Plus] [Inventory] Updating woodChestRows from 2 to 3
[Info :Valheim Plus] [Inventory] Updating personalChestColumns from 3 to 4
[Info :Valheim Plus] [Inventory] Updating personalChestRows from 2 to 3
[Info :Valheim Plus] [Inventory] Updating ironChestColumns from 6 to 7
[Info :Valheim Plus] [Inventory] Updating ironChestRows from 4 to 5
[Info :Valheim Plus] [Inventory] Updating blackmetalChestRows from 4 to 5
[Info :Valheim Plus] [Inventory] Done with section.
[Info :Valheim Plus] [Items] Section is enabled.
[Info :Valheim Plus] [Items] Updating baseItemWeightReduction from 0 to -13
[Info :Valheim Plus] [Items] Updating itemStackMultiplier from 1 to 0
[Info :Valheim Plus] [Items] Done with section.
[Info :Valheim Plus] [Kiln] Section is enabled.
[Info :Valheim Plus] [Kiln] Updating autoFuel from False to True
[Info :Valheim Plus] [Kiln] Done with section.
[Info :Valheim Plus] [LootDrop] Section is NOT enabled.
[Info :Valheim Plus] [Map] Section is enabled.
[Info :Valheim Plus] [Map] Updating exploreRadius from 50 to 100
[Info :Valheim Plus] [Map] Updating displayCartsAndBoats from False to True
[Info :Valheim Plus] [Map] Done with section.
[Info :Valheim Plus] [MonsterProjectile] Section is NOT enabled.
[Info :Valheim Plus] [Oven] Section is NOT enabled.
[Info :Valheim Plus] [Pickable] Section is NOT enabled.
[Info :Valheim Plus] [Player] Section is NOT enabled.
[Info :Valheim Plus] [PlayerProjectile] Section is NOT enabled.
[Info :Valheim Plus] [SapCollector] Section is NOT enabled.
[Info :Valheim Plus] [Server] Section is enabled.
[Info :Valheim Plus] [Server] Updating serverSyncHotkeys from True to False
[Info :Valheim Plus] [Server] Done with section.
[Info :Valheim Plus] [ShieldGenerator] Section is NOT enabled.
[Info :Valheim Plus] [Shields] Section is NOT enabled.
[Info :Valheim Plus] [Smelter] Section is enabled.
[Info :Valheim Plus] [Smelter] Updating autoFuel from False to True
[Info :Valheim Plus] [Smelter] Done with section.
[Info :Valheim Plus] [SpinningWheel] Section is NOT enabled.
[Info :Valheim Plus] [Stamina] Section is NOT enabled.
[Info :Valheim Plus] [StaminaUsage] Section is NOT enabled.
[Info :Valheim Plus] [StructuralIntegrity] Section is NOT enabled.
[Info :Valheim Plus] [Tameable] Section is NOT enabled.
[Info :Valheim Plus] [Time] Section is NOT enabled.
[Info :Valheim Plus] [Turret] Section is NOT enabled.
[Info :Valheim Plus] [ValheimPlus] Section is enabled.
[Info :Valheim Plus] [ValheimPlus] Done with section.
[Info :Valheim Plus] [Wagon] Section is NOT enabled.
[Info :Valheim Plus] [Ward] Section is NOT enabled.
[Info :Valheim Plus] [Windmill] Section is NOT enabled.
[Info :Valheim Plus] [WispSpawner] Section is NOT enabled.
[Info :Valheim Plus] [Workbench] Section is NOT enabled.
[Info :Valheim Plus] Downloading config from: ‘https://github.com/Grantapher/ValheimPlus/releases/download/0.9.16.2/valheim_plus.cfg’
[Info :Valheim Plus] Configuration file loaded successfully.
[Info :Valheim Plus] Applying patches.
[Info :Valheim Plus] Patches successfully applied.
[Info :Valheim Plus] ValheimPlus [0.9.16.2] is up to date.
[Info :Valheim Plus] ValheimPlus done loading.
[Info : BepInEx] Loading [Display BepInEx Info In-Game 2.0.2]
[Message: BepInEx] Chainloader startup complete
[Warning: Unity Log] 05/07/2025 12:59:26: Fetching PlatformPrefs ‘GuiScale’ before loading defaults
[Warning: Unity Log] 05/07/2025 12:59:26: Fetching PlatformPrefs ‘ControllerLayout’ before loading defaults
[Info : Unity Log] 05/07/2025 12:59:26: Initializing loading indicator instance
[Info : Unity Log] 05/07/2025 12:59:26: Starting to load scene:start.unity (169d7618616154c03be07e9ad3af5893)
[Info : Unity Log] 05/07/2025 12:59:26: Set background loading budget to Normal
##diagnostics
| OS | Linux |
| Platform | Ubuntu 24.04.2 |
| System Type | x86_64 |
| Hardware Platform | ASUSTeK COMPUTER INC. PRIME B760M-A D4 |
| CPU Model | 13th Gen Intel(R) Core™ i5-13500 |
| CPU Layout | 1S/10C/20T |
| Installed RAM | 64105 |
| Virtualization | None |
| Network Mode | Standard |
| Module | ADSModule |
| Module Application | Application Deployment |
| Loaded Plugins | FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin, AnalyticsPlugin |
| Application Name | AMP |
| Application Version | 2.6.1.6 |
| Codename | Phobos |
| Tools Version | 2.6.1.6 |
| Release Stream | Mainline |
| Build Spec | Release |
| Build Date | 21/04/2025 13:43 |
| InstanceID | f300c2cc-c631-44f6-8ee0-f93d15625ec9 |
| Last Executable | |
| Last Arguments | |
| Last Process ID | 289366 |
