**Hello I’m still fairly new to using Amp. I have Amp installed on my Unraid OS as a docker application and I am trying to get a Dune Awakening Server up and running but keep running into a Battleground permissions errors and the server refuses to start. I’ve tried regenerating a new Self Host Server token, I’ve made sure all the ports that need to be forwarded are correctly forwarded, I consulted ChatGPT and it has run me through several different things to do, I tried changing the Region to Europe and North America. I’ve tried leaving the FLS field blank, then I tried inputting my actual assigned FLS world name into the FLS field with still no luck. here are is my Server log text.
Only the last 1000 lines are shown here. Check the log file for full history.
UpdateUI: skip show logo
Steam Console Client (c) Valve Corporation - version 1778284286
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “3104830”
Waiting for client config…OK
Waiting for user info…OK
app_update 3104830 validate
Update state (0x5) verifying install, progress: 6.44 (335267840 / 5203908284)
Update state (0x5) verifying install, progress: 27.24 (1417398272 / 5203908284)
Update state (0x5) verifying install, progress: 48.43 (2520500224 / 5203908284)
Update state (0x5) verifying install, progress: 69.91 (3638282240 / 5203908284)
Update state (0x5) verifying install, progress: 91.49 (4761307136 / 5203908284)
Update state (0x0) unknown, progress: 0.00 (0 / 0)
Success! App ‘3104830’ fully installed.
quit
Unloading Steam API…OK
[update] [INFO] Extracting Funcom server binaries. This may take several minutes without visible activity.
[update] [INFO] [postgres] already extracted, skipping
[update] [INFO] [mq] already extracted, skipping
[update] [INFO] [director] already extracted, skipping
[update] [INFO] [text-router] already extracted, skipping
[update] [INFO] [gateway] already extracted, skipping
[update] [INFO] [db-utils] already extracted, skipping
[update] [INFO] [game-server] already extracted, skipping
[update] [INFO] Adjusting binary loaders for non-container hosts…
[update] [INFO] patched: director/Tools/Battlegroups/Director/BattlegroupDirector/Director
[update] [INFO] patched: text-router/Tools/Battlegroups/TextRouter/TextRouter/TextRouter
[update] [INFO] patched: gateway/usr/local/bin/python3.12
[update] [INFO] patched: db-utils/usr/local/bin/python3.12
[update] [INFO] patched: mq/opt/erlang/lib/erlang/erts-14.2.5.12/bin/beam.smp
[update] [INFO] patched: postgres/usr/local/bin/postgres
[update] [INFO] patched: postgres/usr/local/bin/initdb
[update] [INFO] patched: postgres/usr/local/bin/psql
[update] [INFO] patched: postgres/usr/local/bin/createdb
[update] [INFO] patched: postgres/usr/local/bin/createuser
[update] [INFO] patched: postgres/usr/local/bin/pg_ctl
[update] [INFO] patched: postgres/usr/local/bin/pg_isready
[update] [INFO] patched: postgres/usr/local/bin/pg_dump
[update] [INFO] patched: postgres/usr/local/bin/pg_restore
[update] [INFO] patched: erts/erlexec
[update] [INFO] patched: erts/ct_run
[update] [INFO] patched: erts/dialyzer
[update] [INFO] patched: erts/dyn_erl
[update] [INFO] patched: erts/epmd
[update] [INFO] patched: erts/erlc
[update] [INFO] patched: erts/erl_call
[update] [INFO] patched: erts/erl_child_setup
[update] [INFO] patched: erts/escript
[update] [INFO] patched: erts/heart
[update] [INFO] patched: erts/inet_gethost
[update] [INFO] patched: erts/run_erl
[update] [INFO] patched: erts/typer
[update] [INFO] patched: erts/yielding_c_fun
[update] [INFO] patched: os_mon/memsup
[update] [INFO] patched: os_mon/cpu_sup
[update] [INFO] glibc-linked: game-server/DuneSandboxServer (no patch needed)
[update] [INFO] Activating admin-editable config keys…
[update] [INFO] Setting file ownership…
[update] [INFO] Update complete: success.
[prestart] [INFO] Running pre-start setup…
[prestart] [INFO] Bind IP: 0.0.0.0
[prestart] [INFO] External IP: 24.61.246.168
[prestart] [INFO] World title: The Shire
[prestart] [INFO] Region: North America Test
[prestart] [INFO] Verifying world identity…
[prestart] [INFO] HostId: BF03EE1E0F037C6A
[prestart] [INFO] WorldName: sh-bf03ee1e0f037c6a
[prestart] [INFO] Rendering runtime configuration…
[prestart] [INFO] Pre-start setup: success.
[postgres] [INFO] Starting Postgres on 127.0.0.1:15432…
[postgres] [INFO] starting postgres
[postgres] [INFO] Postgres ready: success (pid 682)
[mq-admin] [INFO] Starting RabbitMQ admin broker on 127.0.0.1:5672…
[mq-admin] [INFO] RabbitMQ admin broker ready: success (pid 705)
[mq-game] [INFO] Starting RabbitMQ game broker on 0.0.0.0:5673 (TLS)…
[mq-game] [INFO] RabbitMQ game broker ready: success (pid 980)
[text-router] [INFO] Starting Text Router on 127.0.0.1:5059…
[text-router] [INFO] starting text-router
[text-router] [INFO] Text Router ready: success (pid 1183)
[director] [INFO] Starting Battlegroup Director on 127.0.0.1:11717…
[director] [INFO] starting director
[15:17:25 1 ERR IGWO] Missing required environment variable for IGWO. Found host: , port: 6443, bgName: sh-bf03ee1e0f037c6a
[15:17:25 1 DBG Main] Overriding user in [Database] with value ‘dune’ from environment variable ‘Database_user’
[15:17:25 1 DBG Main] Overriding name in [Database] with value ‘dune’ from environment variable ‘Database_name’
[15:17:25 1 DBG Main] Overriding address in [Database] with value ‘127.0.0.1:15432’ from environment variable ‘Database_address’
[15:17:25 1 DBG Main] Overriding password in [Database] with value ‘dune’ from environment variable ‘Database_password’
[15:17:25 1 DBG Main] Database information found: Host=127.0.0.1:15432;Port=15431;Username=dune;Password=dune;Database=dune;Keepalive=0
[15:17:25 1 INF Main] Created database info with derived port 15432: Host=127.0.0.1;Port=15432;Username=dune;Password=dune;Database=dune;Keepalive=0
[15:17:25 1 INF Main] * Initializing game database
[15:17:25 1 DBG Main] Database Branch: “dune”
[15:17:25 1 INF DB ] Connecting to database: ‘dune’ at 127.0.0.1:15432
[15:17:26 9 INF Main] Generated new game credentials: bgd.sh-bf03ee1e0f037c6a.M8wnnovzTEu3DypjLJqy6Q.game / GF27RCSx3ggAAF7IP2JgBOukGQCxYZFXKiIfQaDes0axoIQxVXSj05Edd53pXWT7
[15:17:26 9 INF Main] Session Correlation Id: 1778699846338
[15:17:26 9 INF Main] Initialize connection to message queue
[15:17:26 9 INF Main] Generated new admin credentials: bgd.sh-bf03ee1e0f037c6a.M8wnnovzTEu3DypjLJqy6Q.admin / LTzMRCSx3ggAAF7IP2JgBKKsJfPQwUq2xZ/MH6fqrfjnPvKTFYNWa0aWApQYg2CK
Fetching FLS Environment…
* Fetching config from /home/amp/.ampdata/instances/DuneAwakening01/duneawakening/extracted/director/DuneSandbox/Config/DefaultEngine.ini
[15:17:26 9 INF Main] Found FLS Environment: through the Default Environment variable (FuncomLiveServices__DefaultFlsEnvironment): beta
Chose to use environment: beta!
[15:17:26 9 WRN Main] Ggwp config not available at /home/amp/.ampdata/instances/DuneAwakening01/duneawakening/extracted/director/DuneSandbox/Config/DefaultEngine.ini.
[15:17:26 9 INF Main] Initialize connection to FLS environment ‘beta’
[15:17:26 9 INF Main] ServiceAuthToken override will be used to authenticate FLS requests.
[15:17:43 9 ERR FLSAPI] (“api/Director_InitializeDirector”) HTTP Request Error: System.Net.Http.HttpRequestException: Response status code does not indicate success: 500 (Internal Server Error).
at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
at BattlegroupDirector.Fls.Api.ExecuteAzureApi[R](String ApiName, Object Args, Int32 FlsFunctionVersion)
Response Content: {“ErrorCode”:403002,“Code”:403,“Status”:“Forbidden”,“Error”:“ACCESS_DENIED”,“ErrorMessage”:“Error in InitializeDirectorAsync: You don’t have permission to perform this operation - Invalid Authorization to manage SelfHosted Battlegroup: sh-bf03ee1e0f037c6a.”} | Arguments: “{“RegionId”:“North America Test”,“BattlegroupId”:“sh-bf03ee1e0f037c6a”,“FlsClientVersion”:1,“FlsFunctionVersion”:1,“PlatformName”:“director”}”
[15:17:43 9 ERR Main] Failed to execute critical Azure API function : “api/Director_InitializeDirector”.
[15:18:05 14 ERR FLSAPI] (“api/Director_InitializeDirector”) HTTP Request Error: System.Net.Http.HttpRequestException: Response status code does not indicate success: 500 (Internal Server Error).
[15:18:05 14 ERR Main] Failed to execute critical Azure API function : “api/Director_InitializeDirector”.
[15:18:22 9 ERR FLSAPI] (“api/Director_InitializeDirector”) HTTP Request Error: System.Net.Http.HttpRequestException: Response status code does not indicate success: 500 (Internal Server Error).
[15:18:22 9 ERR Main] Failed to execute critical Azure API function : “api/Director_InitializeDirector”.
[director] [ERROR] Battlegroup Director failed to listen within 60s
[postgres] [INFO] Postgres ready: success (pid 1696)
[mq-admin] [INFO] RabbitMQ admin broker ready: success (pid 1719)
[mq-game] [INFO] RabbitMQ game broker ready: success (pid 1737)
[text-router] [INFO] Text Router ready: success (pid 1764)
[15:20:46 1 ERR IGWO] Missing required environment variable for IGWO. Found host: , port: 6443, bgName: sh-bf03ee1e0f037c6a
[15:20:46 1 DBG Main] Overriding password in [Database] with value ‘dune’ from environment variable ‘Database_password’
[15:20:46 1 DBG Main] Overriding user in [Database] with value ‘dune’ from environment variable ‘Database_user’
[15:20:46 1 DBG Main] Overriding name in [Database] with value ‘dune’ from environment variable ‘Database_name’
[15:20:46 1 DBG Main] Overriding address in [Database] with value ‘127.0.0.1:15432’ from environment variable ‘Database_address’
[15:20:46 1 DBG Main] Database information found: Host=127.0.0.1:15432;Port=15431;Username=dune;Password=dune;Database=dune;Keepalive=0
[15:20:46 1 INF Main] Created database info with derived port 15432: Host=127.0.0.1;Port=15432;Username=dune;Password=dune;Database=dune;Keepalive=0
[15:20:46 1 INF Main] * Initializing game database
[15:20:46 1 DBG Main] Database Branch: “dune”
[15:20:46 1 INF DB ] Connecting to database: ‘dune’ at 127.0.0.1:15432
[15:20:47 1 DBG Main] Overriding password in [Database] with value ‘dune’ from environment variable ‘Database_password’
[15:20:47 1 DBG Main] Overriding user in [Database] with value ‘dune’ from environment variable ‘Database_user’
[15:20:47 1 DBG Main] Overriding name in [Database] with value ‘dune’ from environment variable ‘Database_name’
[15:20:47 1 DBG Main] Overriding address in [Database] with value ‘127.0.0.1:15432’ from environment variable ‘Database_address’
[15:20:47 1 DBG Main] Database information found: Host=127.0.0.1:15432;Port=15431;Username=dune;Password=dune;Database=dune;Keepalive=0
[15:20:47 1 INF Main] Created database info with derived port 15432: Host=127.0.0.1;Port=15432;Username=dune;Password=dune;Database=dune;Keepalive=0
[15:20:47 1 INF Main] * Initializing game database
[15:20:47 1 DBG Main] Database Branch: “dune”
[15:20:47 1 INF DB ] Connecting to database: ‘dune’ at 127.0.0.1:15432
[15:20:47 9 INF Main] Generated new game credentials: bgd.sh-bf03ee1e0f037c6a.y660hkpq_keHv_t7XZejOQ.game / RIXmvCSx3ggAAF7IP2JgBNaB+aKnX9lk2ljDvwhXrvxgNSVn3KDHyM5el/F2uIBQ
[15:20:47 9 INF Main] Session Correlation Id: 1778700047947
[15:20:47 9 INF Main] Initialize connection to message queue
[15:20:48 9 INF Main] Generated new admin credentials: bgd.sh-bf03ee1e0f037c6a.y660hkpq_keHv_t7XZejOQ.admin / 4134vCSx3ggAAF7IP2JgBPP7KrxG8Qs5v6g81jncim7DAPL3M34SzQpUCtK1MFca
[15:20:48 9 INF Main] Initialize connection to message queue
[15:20:48 9 INF Main] Found FLS Environment: through the Default Environment variable (FuncomLiveServices__DefaultFlsEnvironment): beta
[15:20:48 9 WRN Main] Ggwp config not available at /home/amp/.ampdata/instances/DuneAwakening01/duneawakening/extracted/director/DuneSandbox/Config/DefaultEngine.ini.
[15:20:48 9 INF Main] Initialize connection to FLS environment ‘beta’
[15:20:48 9 INF Main] ServiceAuthToken override will be used to authenticate FLS requests.
[15:21:08 9 ERR FLSAPI] (“api/Director_InitializeDirector”) HTTP Request Error: System.Net.Http.HttpRequestException: Response status code does not indicate success: 500 (Internal Server Error).
[15:21:08 9 ERR Main] Failed to execute critical Azure API function : “api/Director_InitializeDirector”.
[15:21:27 16 ERR FLSAPI] (“api/Director_InitializeDirector”) HTTP Request Error: System.Net.Http.HttpRequestException: Response status code does not indicate success: 500 (Internal Server Error).
[15:21:27 16 ERR Main] Failed to execute critical Azure API function : “api/Director_InitializeDirector”.
[15:21:30 12 ERR FLSAPI] (“api/Director_InitializeDirector”) HTTP Request Error: System.Net.Http.HttpRequestException: Response status code does not indicate success: 500 (Internal Server Error).
[15:21:30 12 ERR Main] Failed to execute critical Azure API function : “api/Director_InitializeDirector”.
