Dune Awakening Initial Start Issue
OS Name/Version: Windows Server 2025
Product Name/Version: AMP Release “Deimos” v2.7.2.8, built 20/05/2026 06:54
Problem Description: Server seems to always timeout
[prestart] [INFO] Verifying world identity...
[prestart] [INFO]   HostId: A04F0255DB3C9F7A
[prestart] [INFO]   WorldName: sh-a04f0255db3c9f7a-xnqpgc
[prestart] [INFO] Rendering runtime configuration...
[prestart] [INFO]   director.ini: injected missing map section [ CB_SurvivalChallenge_Station_15 ]
[prestart] [INFO]   merged UserOverrides.ini into UserGame.ini
[prestart] [INFO] Pre-start setup: success.
[postgres] [INFO] Starting Postgres on 127.0.0.1:15432...
[postgres] [INFO] starting postgres
[postgres] [INFO] Postgres ready: success (pid 585)
[migrate] [INFO] Running Funcom DB migrations (Database/Upgrade/*.sql)...
[migrate] DO
[migrate] [2026-05-25 14:52:40,396][ERROR][app] Command psql took 600.0000143051147 seconds that is longer than allowed 600.0 seconds, aborting
[migrate] Contact #help-engine-and-editor for help
[migrate] [ERROR] updatedb.py exited 50 (unrecognised) — refusing to proceed; check [migrate] lines above for context.
  • Step 1 This is a fresh install of AMP and Docker Desktop
  • Step 2 Followed setup instructions
  • Step 3 Tried stopping and starting the server instance, updating, and deleted and reinstall
Actions taken to resolve so far: Pretty much step 3 I have tried this multiple times and tried checking online to see if I could find a fix, but no luck so far.
Just adding.
Not sure if it’s useful info or not but I noticed the Deployment log was scrolling this continuously
WebSocket proxy failed to connect to remote ‘ws://localhost:8081/stream/2a7f1761-123e-4913-aacb-07ef5f4e3ad2’: The server returned status code ‘404’ when status code ‘101’ was expected.
Try this; this helped me: https://discourse.cubecoders.com/t/dune-awakening-amp-serveron-windows-hangs-on-run-schema-migrations/40441/15
Tried this and still get the same error.
[migrate] [INFO] Running Funcom DB migrations (Database/Upgrade/*.sql)…
[migrate] DO
[migrate] [2026-05-26 18:07:42,214][ERROR][app] Command psql took 600.0000121593475 seconds that is longer than allowed 600.0 seconds, aborting
A new version of the Dune instance template is available. Update your instance via ADS and then update the Dune server inside the instance (necessary to get the new scripts)
[migrate] [INFO] still working — 20m 31s elapsed, latest: (idle)
[migrate] [INFO] still working — 21m 1s elapsed, latest: (idle)
[migrate] [INFO] still working — 21m 31s elapsed, latest: (idle)
[migrate] [INFO] still working — 22m 1s elapsed, latest: (idle)
I’m pretty sure i have followed all the instructions accurately
[migrate] [INFO] still working — 61m 2s elapsed, latest: (idle)
[migrate] [2026-05-27 00:26:42,474][ERROR][app] Command psql took 3600.0000233650208 seconds that is longer than allowed 3600.0 seconds, aborting
[migrate] [INFO] updatedb.py finished after 3668s (exit=50)
No idea then as the migration is part of what funcom ship. Only thing I can suggest is shutting down everything that isn’t dune so it has absolutely zero contention.
So that’s it sorry about your bad luck…
I mean you’re the coder guy you have no idea why it just says idle constantly?
I’m running this directly after a fresh shut down and boot, my setup is R730XD with Intel(R) Xeon(R) CPU E5-2680 v3 @ 2.50GHz (2.50 GHz) (2 processors) and 128GB ram, I don’t feel like it’s the hardware, there’s gotta be something stupid I am missing somewhere. Is there any other info I can give you to help with what is going on? I did install and start a Conan Exiles server just to see if anything worked in AMP and it seemed to update and load up just fine. Could this be a Firewall thing or a specific port i need to open in my router settings, I just do not have a good idea where to even start looking.
simular error apart from yours is Exited 50 mine 137
[migrate] [INFO] updatedb.py finished after 3737s (exit=137)
[migrate] [ERROR] updatedb.py exited 137 (unrecognised) — refusing to proceed; check [migrate] lines above for context.
The migration is part of Funcoms code, not something I built. It might be worth raising with them that the migration is taking a long time.
Guess I’ll give it a try, what a waste of $40, I could have got the server to not run by myself…
Installing the standalone version on windows pro 11 with Hyper-v works, just thought it would be nice to have it in AMP with all my other games, so not my pc setup, i assume this points to an AMP/Desktop docker issues or some other setting between the 2 of them.
Wait for later today/tomorrow when I’m hoping to ship a new template. Will be addressing several issues.
