Dune awakening first run issue
OS Name/Version: Windows Server 2025 Datacenter
Product Name/Version: AMP Release “Deimos”
v2.7.2.8, built 08/06/2026 00:16
Problem Description: psql fatal error followed by idle migrate and timeout
[prestart] [INFO] Pre-start setup: success.
[postgres] [INFO] Starting Postgres on 127.0.0.1:15432...
[postgres] [INFO] starting postgres
[postgres] [INFO] Postgres ready: success (pid 709)
[migrate] [INFO] Running Funcom DB migrations (Database/Upgrade/*.sql)...
[migrate] psql: error: connection to server at "127.0.0.1", port 15432 failed: FATAL:  the database system is starting up
[migrate] [INFO] DB-command timeout set to 3600s (Funcom default: 600s)
[migrate] [INFO] still working — 0m 30s elapsed, latest: (idle)
[migrate] [INFO] still working — 1m 0s elapsed, latest: (idle)
[migrate] [INFO] still working — 1m 30s elapsed, latest: (idle)
[migrate] [INFO] still working — 2m 0s elapsed, latest: (idle)
  • Step 1 Just reinstalled Dune Server
  • Step 2 Ran update and restarted instance
  • Step 3 started server up and received the idle timeout,
Actions taken to resolve so far: I have done the previous steps multiple times over the past couple weeks and get to the exact same spot every time. I have tried asking here, waiting on updates and just googling things to try, nothing has helped at this point. I have tried the suggestions on " Dune Awakening amp serveron windows -hangs on run schema migrations - #14 by Martijn_van_Dortmont " it did not work for my issue.
