I am unable to get Dune Awakening to launch after updating Amp this morning.
OS Name/Version: Ubuntu 24.04.4 LTS (GNU/Linux 6.8.0-136-generic x86_64)
Product Name/Version: AMP Release “Proteus” v2.8.0.4, built 24/07/2026 17:13
It appears there is an error in the DB migration that happens on server startup. Postgress starts but then says the DB doesn’t exist. Should I try to restore from backup? as it is I have been having to backup the whole AMP server since Dune awakening backups have not been working.
[update] [INFO] Update complete: success.
[prestart] [INFO] Running pre-start setup...
[prestart] [INFO] Bind IP: 0.0.0.0
[prestart] [INFO] External IP: 100.108.57.99
[prestart] [INFO] World title: Sandors Dune Awakening - Powered by AMP
[prestart] [INFO] Region: North America
[prestart] [INFO] Verifying world identity...
[prestart] [INFO] HostId: CE2DBDBED638CB74
[prestart] [INFO] WorldName: sh-ce2dbdbed638cb74-tuosjj
[prestart] [INFO] Rendering runtime configuration...
[prestart] [INFO] director.ini: injected InstancingMode CB_Overland_S_08=ClassicalInstancing (director.ini)
[prestart] [INFO] director.ini: injected missing map section [ CB_SurvivalChallenge_Station_15 ] (director.ini)
[prestart] [INFO] director.ini: injected InstancingMode CB_SurvivalChallenge_Station_15=ClassicalInstancing (director.ini)
[prestart] [INFO] director.ini: injected InstancingMode CB_Overland_S_08=ClassicalInstancing (director_config.ini)
[prestart] [INFO] director.ini: injected missing map section [ CB_SurvivalChallenge_Station_15 ] (director_config.ini)
[prestart] [INFO] director.ini: injected InstancingMode CB_SurvivalChallenge_Station_15=ClassicalInstancing (director_config.ini)
[prestart] [INFO] director.ini: enabled instance scaling on DLC maps (director.ini)
[prestart] [INFO] director.ini: enabled instance scaling on DLC maps (director_config.ini)
[prestart] [INFO] merged UserOverrides.ini into UserGame.ini
[prestart] [INFO] Pre-start setup: success.
[postgres] [INFO] Starting Postgres on 127.0.0.1:15432...
[postgres] [INFO] starting postgres
[postgres] [INFO] Postgres ready: success (pid 2227)
[migrate] [INFO] Running Funcom DB migrations (Database/Upgrade/*.sql)...
[migrate] psql: error: connection to server at "127.0.0.1", port 15432 failed: FATAL: the database system is starting up
[migrate] [INFO] DB-command timeout set to 3600s (Funcom default: 600s)
[migrate] [2026-07-30 11:18:57,755][INFO][api] Using Postgres installation /AMP/duneawakening/extracted/postgres/usr/local (script=17.4, client=17.4, server=None)
[migrate] [2026-07-30 11:18:57,756][INFO][connection] Connecting to postgresql://postgres@127.0.0.1:15432/postgres
[migrate] [2026-07-30 11:18:57,757][ERROR][app] Connection failed: database postgres does not exist, host 127.0.0.1:15432
[migrate] Contact #help-engine-and-editor for help
[migrate] [INFO] updatedb.py finished after 0s (exit=57)
[migrate] [ERROR] updatedb.py exited 57 (unrecognised) — refusing to proceed; check [migrate] lines above for context.
- Step rebooted and updated and tried to start the server and it fails at the same place every time.
Actions taken to resolve so far: Updated AMP : Updated Ubuntu : updated Dune Awakening : rebooted several times : searched the site and web.
