OS Name/Version: W11 Pro
Product Name/Version: (Always use the full version number - not ‘Latest’) 2.7.2.6 - 20260513.8
Problem Description: Attempting to create an instance with container and getting following issue below each time creating instance
Non-managed instances exist, autoconfigure cannot guarantee that the configuration is valid!
permission denied while trying to connect to the docker API at npipe:////./pipe/docker_engine
Failed to configure new instance Satisfactory01 - Startup failure: Error code 1. Please check the AMP Logs for further info.
Configuration Failed: Startup failure: Error code 1. Please check the AMP Logs for further info.
Create Instance Failed: Startup failure: Error code 1. Please check the AMP Logs for further info.
- Start instance - dune awakening
Reinstalling Docker, Amp & assigning “user” to the docker-user, restarting docker engine, manually starting it.
