There appears to be a bug in Docker 29.4.2 that prevents SteamCMD and Wine from functioning, and possibly other software. We recommend you do not update Docker until a solution is found. We’ve opened an issue with them to investigate further.
opened 03:04PM - 01 May 26 UTC
status/0-triage
kind/bug
area/security/seccomp
version/29.4
### Description
I suspect the cause for the errors below are related to the sec… comp profile being tightened for copyfail prevention. The issue is SteamCMD fails in all 29.4.2 containers due to socket errors.
Steam Console Client (c) Valve Corporation - version 1777415795
-- type 'quit' to exit --
Loading Steam API...CreateBoundSocket: failed to create socket, error [no name available] (38)
OK
force_install_dir "4019830"
Connecting anonymously to Steam Public...Retrying...
Retrying...
Retrying...
os-release:
PRETTY_NAME="Ubuntu 24.04.4 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04.4 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=noble
LOGO=ubuntu-logo
### Reproduce
In this case, I'm a developer for AMP by CubeCoders so the steps are specific to our software.
1) Install AMP
2) Create a game server instance in a Docker container which then starts with a command similar to this: `/usr/bin/docker run --rm -d --name AMP_Astroneer01 -e AMPUSERID=1000 -e AMPGROUPID=1000 -e AMPHOSTPLATFORM=Linux -e AMP_INSTANCE_ID=9f07c3e2-c875-443b-a9c7-07cb0eb1967e -e AMP_MOUNTPOINTS="" -e AMP_CONTAINER=1 -v "/home/amp/.ampdata/instances/Astroneer01":/AMP -v "/home/amp/.ampdata/instances/Astroneer01/.virtualhome":/home/amp --net=host -e AMP_CONTAINER_HOST_NETWORK=1 cubecoders/ampbase:debian +Core.Webserver.Port "8082" +Core.Webserver.IPBinding "0.0.0.0" +Core.AMP.InstanceID "9f07c3e2-c875-443b-a9c7-07cb0eb1967e" +Core.Security.MetricsHMAKKey "Redacted"`
3) Update the game server which uses SteamCMD
### Expected behavior
The container should be able to run a popular tool like SteamCMD by default without additional configuration. I understand the need to prevent an exploit, but the fix must also not limit functionality negatively.
### docker version
```bash
Client: Docker Engine - Community
Version: 29.4.2
API version: 1.54
Go version: go1.26.2
Git commit: 055a478
Built: Fri May 1 10:24:01 2026
OS/Arch: linux/amd64
Context: default
Server: Docker Engine - Community
Engine:
Version: 29.4.2
API version: 1.54 (minimum version 1.40)
Git commit: d329809
Experimental: false
containerd:
Version: v2.2.3
GitCommit: 77c84241c7cbdd9b4eca2591793e3d4f4317c590
runc:
Version: 1.3.5
GitCommit: v1.3.5-0-g488fc13e
docker-init:
Version: 0.19.0
GitCommit: de40ad0
### docker info
```bash
Version: 29.4.2
Context: default
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.33.0
Path: /usr/libexec/docker/cli-plugins/docker-buildx
compose: Docker Compose (Docker Inc.)
Version: v5.1.3
Path: /usr/libexec/docker/cli-plugins/docker-compose
Server:
Containers: 1
Running: 1
Paused: 0
Stopped: 0
Images: 11
Server Version: 29.4.2
Storage Driver: overlayfs
driver-type: io.containerd.snapshotter.v1
Logging Driver: json-file
Cgroup Driver: systemd
Cgroup Version: 2
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local splunk syslog
CDI spec directories:
/etc/cdi
/var/run/cdi
Swarm: inactive
Runtimes: io.containerd.runc.v2 runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 77c84241c7cbdd9b4eca2591793e3d4f4317c590
runc version: v1.3.5-0-g488fc13e
init version: de40ad0
Security Options:
apparmor
seccomp
Profile: builtin
cgroupns
Kernel Version: 7.0.0-3-pve
Operating System: Ubuntu 24.04.4 LTS
OSType: linux
Architecture: x86_64
CPUs: 12
Total Memory: 20GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Experimental: false
Insecure Registries:
::1/128
127.0.0.0/8
Live Restore Enabled: false
Firewall Backend: iptables
### Additional Info
_No response_
I’ll take this chance to remind you all that we offer (and recommend) switching to Podman if running on Linux. You can switch by running getamp installPodman and it’ll install and configure it, if your system supports it.
Version 29.4.3 has now been released and resolves the issue.
