DNS Endpoint Routing
Dear community,
I use the Cloudflare free plan as a DNS server and use an A record as subdomain “play.domain.tld” to connect directly to the instance, otherwise it will to the proxy server IP.
I wanted to add the subdomain to the instance as Primary Endpoint with the subdomain shown as prefix.
Instead of Primary Endpoint “Domain.tld:Port”, should show “Prefix.Domain.tld:Port” or even “Prefix.Domain.tld” if you wanna use SRV records.
You can set it up per instance (SRV) or globaly or maybe per instance group
Do you think this is useful? If you have Cloudflare premium you obviously don’t need this.
Cheers
Michael
