Discord Webhook Scheduler
System Infos:
OS Windows
Platform Windows Server 2022
System Type x86_64
CPU Model AMD Ryzen 9 3900 12-Core Processor
CPU Layout 1S/12C/24T
Installed RAM 131001
Loaded Plugins FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin
Application Name AMPService
Application Version 2.4.8.0
Codename Decadeus
Tools Version 2.4.8
Release Stream Mainline
Build Spec Release
Build Date 29/01/2024 18:40
InstanceID b71c06b5-be08-40f1-8a1a-679cb546df5a
Last Executable C:\AMPDatastore\Instances\Python01\AMP.exe
Last Arguments +Core.Webserver.Port 8086 +Core.Webserver.IPBinding 127.0.0.1 +Core.AMP.InstanceID ---- +FileManagerPlugin.SFTP.SFTPPortNumber 2229 +GenericModule.App.Ports.$ServerPort 7777
Last Process ID 11120
Currently running version 2.4.8 - 20240129.1
OS: Windows Server Data (up2date)
Currently running version 2.4.8 - 20240129.1 of AMP
Ive setup 2 Trigger for my Server with a Discord Webhook. If u press “Run Trigger” nothing happens in our Discord. I use the Stanard installation from AMP, and dont settup up more…all my server are running without errors…
EDIT:
Pictures:
Did you fill out all the fields, and is your webhook formatted properly?
You can also double check to see if your webhook content/embed is formatted properly using a site like this: https://discohook.org/
