OS Name/Version: Windows Server 2022
Product Name/Version: SoulMask
im still getting the message “A required runtime is missing. This is likely to be a C++ or DirectX runtime. You can install them by running ampinstmgr DownloadCPPRuntime
in an elevated command prompt.”
provides syntax highlighting.
- Step 1: installed instance
- Step 2:got that message
- Step 3:
- Step 3:i ran ampinstmgr DownloadCPPRuntime` in an elevated command prompt
- Step 4: rebooted Hardware
- Step 5:same results
