- Apply developer key to instance (ampinstmgr reactivate instance key)
- Start Istance
- Network Port Status now says “No port information available.”
It is worth noting that everything works fine and the ports are indeed available. I ran into this problem using the Discord Bot plugin but it happens when applying the developer key manually and not using the plugin.
