Debian Bash install script hangs on updating package list for debian >=13
OS Name/Version: Debian 13 (Trixie) — running inside a Proxmox VE 9.0.10 VM
Product Name/Version: AMP Installer (getamp.sh) — current version as of October 2025
Problem Description: When running the official AMP installation script on my Debian 13 VM, the process hangs indefinitely at
Updating packages list for Debian >= 13...
The system stays frozen there for several minutes (10 + min) without any error or timeout.
Network connectivity and DNS resolution are working (verified with ping deb.debian.org and curl ``https://getamp.sh).
    1. Created a fresh Debian 13 VM in Proxmox VE 9.0.10 using the netinst ISO.
    2. Logged in as root and updated packages:
      apt update && apt upgrade -y
    3. Ran the official AMP install command:
      bash <(curl -fsSL getamp.sh)
    4. The installer printed:
      Please wait while GetAMP examines your system and network configuration...
      - Checking installed packages...
      - Checking environment...
      - Checking network configuration...
      - Updating packages list for Debian >= 13...
      and then stopped responding.
Verified internet connectivity (ping deb.debian.org → success).
  • Confirmed DNS and HTTPS work (curl -I https://getamp.sh → HTTP 302 redirect).
  • Checked for apt locks (dpkg --configure -a, apt-get -f install).
  • Removed cdrom entries from /etc/apt/sources.list.
  • Manually ran
    apt-get -o Acquire::ForceIPv4=true update
    which completes successfully.
  • Tried re-running the installer with
    bash getamp.sh --skip-update
    to bypass apt update.
Despite this, the standard installer still hangs at the “Updating packages list” stage.
Expected Result:
Installer should complete the package update phase and continue to download and configure AMP.
Actual Result:
Installer stalls indefinitely with no further output.
Additional Information:
  • Proxmox VM specs: 2 vCPUs (Core i3-7th Gen), 5 GB RAM
  • Playit tunnel and Samba services already configured and working
  • UFW active with ports 6712/tcp (SSH) and 8080/tcp (AMP planned) open
    EDIT: the script continues but after a very long time of leaving it running
