DayZ-Expansion-Bundle
19:35:24 [Inputs] Exporting inputs cfg “/home/amp/.ampdata/instances/expentest01/dayz/223350/DayZServerData/users/Survivor\Server.core.xml”
21:35:26
19:35:26 ANIMATION (E): Can’t load 2116157322/Anims/cfg/skeletons.anim.xml
19:35:26 ANIMATION (E): Failed to open file, line 0, column 0
19:35:26 ANIMATION (E): Can’t load 2572331007/Anims/cfg/skeletons.anim.xml
19:35:26 ANIMATION (E): Can’t load 2545327648/Anims/cfg/skeletons.anim.xml
19:35:26 ANIMATION (E): Can’t load 1564026768/Anims/cfg/skeletons.anim.xml
19:35:26 ANIMATION (E): Can’t load 1559212036/Anims/cfg/skeletons.anim.xml
19:35:26 ANIMATION (E): Can’t load Bliss/Anims/cfg/skeletons.anim.xml
21:35:27
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather1.farCloud’.
19:35:27 Warning Message: Trying to access error value.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather1.cloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather2.farCloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather2.cloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather3.farCloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather3.cloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather4.farCloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather4.cloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather5.farCloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/Overcast/Weather5.cloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/LightingNew/C_Day60.spaceIntensity’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/LightingNew/C_Day60.starsIntensity’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/LightingNew/C_Day60.atmosphereIntensity’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld/Weather/LightingNew/C_Day60.NearCloud’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld.volFogOffset’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld.spaceObject’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld.atmosphereObject’.
19:35:27 Atmosphere not loaded, using old ‘sky’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld.nearCloudObject’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld.cloudObject’.
19:35:27 Warning Message: No entry ‘bin\config.bin/CfgWorlds/DefaultWorld.horizonObject’.
21:35:31
*** buffer overflow detected ***: terminated
sh: 1: /home/amp/.ampdata/instances/expentest01/dayz/223350/CrashReporter: not found
bash
Console
21:35:20
19:35:20 String “STR_server_shutdown” listed twice in “Global”
19:35:20 Localization not present: STR_DATE_FORMAT_SHORT
19:35:20 Localization not present: STR_TIME_FORMAT
19:35:20 Localization not present: STR_CONFIG_CONTROLLER_NORMAL_LOOK
19:35:20 Localization not present: STR_CONFIG_CONTROLLER_REVERSED_LOOK
19:35:20 Localization not present: STR_MP_VALIDERROR
19:35:20 Localization not present: STR_MP_CONNECTION_LOOSING
19:35:20 Localization not present: STR_MSG_MP_NO_PASSWORD
19:35:20 Localization not present: STR_MSG_LAUNCH_GAME
19:35:20 Localization not present: STR_LOAD_INIT
19:35:20 Localization not present: STR_LOAD_WORLD
19:35:20 Localization not present: STR_LOAD_GAME
19:35:20 Localization not present: STR_SAVE_GAME
19:35:20 Localization not present: STR_MP_DISCONNECT
19:35:20 Localization not present: STR_MP_CONNECTING
19:35:20 Localization not present: STR_MP_TIMEOUT
19:35:20 Localization not present: STR_DISP_CLIENT_TEXT_EDIT
19:35:20 Localization not present: STR_MP_LOGIN_QUEUE_FULL
19:35:20 Initializing stats manager.
I’ve been trying to get a new server for a long time!!!
the local server is installed without problems!!!
Unable to complete task
This task could not be completed: Starting DayZ (Stable)… - - State: 3.
Application stopped unexpectedly with exit code 134.
OS Name/Version:
provides syntax highlighting.
  • Step 1
  • Step 2
  • Step 3
