| Operating System | Windows - Windows 10 Pro on x86_64 |
| Product | AMP ‘Callisto’ v2.5.1.0 (Mainline) |
| Virtualization | Xen |
| Application | Seven Days To Die |
| Module | GenericModule |
| Running in Container | No |
| Current State | Stopped |
I created also a ticket on discord, but here it is in another way. I installed a 7d2d instance via the instances tab, then changed the settings as followed: Release stream: alpha20.7 / Config File Version: Undead Legacy Stable. Updated the whole thing, and then on startup I just get an error message and the server outputs itself as “running” but I cant connect to it. I attached the log to it. Please help me to properly install undead legacy.
- Created the 7d2d instance
- Release stream changed to alpha20.7 to match Undead Legacy version
- Config file Version: Undead legacy stable
- Changed map Size to 10k size in config.
- Clicked on “Update Server” to let amp download everything needed
- Tried to run the server, but only getting a whole lot weird console outputs about EOS
- disabled EOS
- Tried running it again. It appears to run, “correctly” but in the Status tab are no ports open, that are necessary to connect to the server
