| Field |
Value |
| Operating System |
| Product |
AMP ‘Callisto’ v2.5.1.8 (Mainline) |
| Virtualization |
Docker |
| Application |
Satisfactory |
| Module |
GenericModule |
| Running in Container |
Yes |
| Current State |
Ready |
Without server bandwidth settings, All Satisfactory servers are reverting back to “Medium” when some saves require higher network quality settings for player to join without timing out.
- Launch Server
- Attempt to customize
- Notice theres no Network Quality Settings
I have had to apply the Network Quality setting in the server management screen in game and then save the server/world and return to AMP and shutdown and restart the game server instance.
That is the only way I can find to change the server’s network quality setting and get it to stick.
But if there ever becomes better support and server settings I would love to see that as well.
Can you give any information on what changing the Network Quality setting in the server manager does for the server ini files?
Specifically what each of Low, Medium, High and Ultra correspond to
