Customization with Palworld - Palworld game setting not adjusting in game
Product AMP ‘Phobos’ v2.6.2.4 (Mainline)
Application Palworld
Current State Starting
Hi,
I’ve tried to manually adjust the Egg incubation time in my server settings. The original timing was 72.00000, which i’ve set back to 1.00000, 0.10000 or even 0.00000
None of the changes seemed to have any effect on the egg incubation time, however in my singleplayer server this always seemed to work.
Can you please help me in this matter as we have no clue how to get this done now… It should work but it isn’t
  • Opening file manager
  • opening palworldsettings ini
  • adjusting egg default egg incubation time to 0.00000
Change it the AMP settings - Configuration > Palworld
Where is this setting in the indicated location?
I’ve attempted to change the setting in the Linux configs, Windows config, Palworld Configs, and in the UI there is not a setting for this.
It ends up resetting the changes every time you start the server, and typing “PalEggDefaultHatchingTime=2.000000” in custom settings does nothing.
Disregard I’m an idiot.
Palworld settings → Egg Hatching Time: Sets the time to incubate a massive egg → Customize setting
I passed over this multiple times because I am apparently blind, thank you Greelan
You can use the search box to find settings too xD
