Customization with Palworld - I need to get ue4ss running on my palworld
Application Palworld
Before signing up, I understood that your VPS server accepted mods and .lua files, but everything I try that uses ue4ss doesn’t work.
  • I’ve already tried downloading it, asking Kodde for help, and using Google’s AI.
  • Can someone clarify or help me? It’s very difficult to communicate here; I’m not seeing the answers.
  • Is it possible to install UE4SS? I tried to find a Linux version of PalGuard, but nothing works.
You have to use the Palworld (Modded) instance, since UE4SS (and mods generally) only work with the Windows version of Palworld - so the Palworld (Modded) runs the Windows executable using Wine on Linux to facilitate modding on Linux.
Options to install UE4SS and workshop mods are in the UI. Use the search box in the instance to find them.
entao, eu fiz a instalação da versão modifica, criou as estruturas mas tudo vazio, sera que fiz algo errado?
